MC - FTB Direwolf20 1.19 Installation
OS Name/Version: Ubuntu 22.04
Product Name/Version: AMP Decadeus 2.4.4
I can’t start a Direwolf20 FTB New Source server.
I search some install guide, and I found everyone start the server with start.sh and not with a Forge.jar, could we run the .sh with amp ? Or there is another guide here to launch a Direwolf20 Server with amp ?
  • Run instance
  • Choose server setting : FTB Presents Direwolf20 1.19
  • Donwload / Update
  • Try to run
See the following guide:
After doing that, just tell AMP which Forge version is running, and it’ll start up as normal.
Thanks for your help !
I try enix_lin tutorial and it’s work ! Thanks !
That’s not really how you’re supposed to do it, it may work but AMPs resource monitor likely won’t function.
Just delete the .bat/.sh file and choose the correct forge version within AMP and keep the Server jar on autoselect. AMP knows how to start newer forge Versions. Also, Just renaming it to .jar won’t work.
