Manually, remotely revoke activations?
Is there a way to turn off an amp activation on a machine I no longer have access to, or has hardware damage? Or do I just have to accept that that activation is forever gone?
I’m also looking for an answer to this since i’ve used all my 5 instances on the same machine that i have upgraded. (latest instance was removed after CPU upgrade). I only have one machine but the usage is listed as 5/5.
Apparently after enough time without use some of them will disappear? Maybe?
Reach out to support and ask for help. If you’d be so kind, update this thread once they reply!
There does’nt seem to be another way to reach out other than this forum, so hopefully someone will see this soon
I’m also wondering about how to do this. They do have a discord… I wonder if any of the devs are on there. It might be worth a shot to try reaching out there.
