OS Name/Version: Ubuntu 24.04.1
Product Name/Version: (Always use the full version number - not ‘Latest’) 2.6.0.4 - 20241106.1
Updated my AMP Controller and Target and I believe my Ubuntu target has a full disk drive. I'm unable to connect to it using the Controller.
Is there a way to manually delete an instance?
N/A
Actions taken to resolve so far: Not much to provide as I’m fairly certain the issue is disk space. Looking for advice on freeing up some space
You should be able to remote into the Target over SSH and delete extra backups and all that.
AMP’s files are stored under /home/amp/.ampdata/instances
You can safely edit files as the amp Linux user (sudo su -l amp to switch to the user)
To see if it’s a disk issue beforehand you can run df -h
Well I’ve managed to free up enough space on the disk (i think) it’s currently sitting at 87% full.
I am currently running into this error in the Deployment Logs from my Controller server
22:23:02
Failure communicating with http://EDITED:8080/ - check that the host is available and reachable.
HttpRequestException
[0] (HttpRequestException) : No connection could be made because the target machine actively refused it. (EDITED:8080)
at Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
at Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(QueueItem queueItem)
at Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
at Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
at AMPAPI.RemoteInstance.GetResponseDynamic(String Module, String Method, Object Parameters)
at AMPAPI.RemoteInstance.API_Core.Login(String username, String password, String token, Boolean rememberMe)
at InstanceManagerPlugin.RemoteInstanceManager.Login(String username, String password, String token)
SocketException
[1] (SocketException) : No connection could be made because the target machine actively refused it.
at Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|285_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken)
Failed to update EDITED_GameServer_Name - Could not connect to the remote instance at http://EDITED/. Connection Refused
This all started after I updated my AMP to the latest version
eh, there’s no firewall on the linux target server and it always was able to connect to the Controller before attempting to update.
I ended up backing up my instances and rolling the server snapshot back prior to target setup, expanded the main disk, and rebuilt the target connection.
Annoying and inconvenient, but did the job.
