Product Name/Version: AMP Release “Triton” v2.3.2, built 31/01/2022 18:02
I am having a problem where clicking the manage button on one of my Minecraft instances from the instance manager does nothing. I have another Minecraft instance that is on the same version and it does not have the same problem. I was able to log into the 2 times after I updated the instances to the above version
When I view the console after clicking the manage button I see the following errors:
That seems to have resolved my issue, however that command also seems to have changed the port on which the ADS instance is running on from 8080 to 8085. Any ideas why it would have done that and/or how to change it back?
If you were using an old version of ampinstmgr then it might have changed the port due to it always trying to move ADS away from an in-use port (including ADSs original port).
Update ampinstmgr, then use ampinstmgr rebind to put it back on 8080, then use repairauth again.
