Lost access to Web UI
OS Name/Version: Debian 12.12
Product Name/Version: v2.6.4.2 built 03/12/2025 15:30
Problem Description: Not sure what happened, it’s been running fine for about a year. The only thing i did to it was once a week run apt update && apt upgrade -y The game servers themselves seem to be running fine i just can’t access the web url.
I tired a different browser,
restarted the instance and physical machine.
ran command ampinstmgr start ADS (ADS01 is already running)
Latest Log
```[18:34:57] [Program Info/1] : Starting AMP version 2.6.4.0 (Phobos), built 14/11/2025 00:12
[18:34:57] [Program Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[18:34:57] [Core Info/1] : Deleting 4 old log files…
[18:34:57] [Program Info/1] : Running in a Proxmox LXC Container environment.
[18:34:57] [Program Info/1] : OS: Linux / x86_64
[18:34:57] [Program Info/1] : CPU: AMD Ryzen 9 5950X 16-Core Processor (16C/32T)
[18:34:57] [Program Info/1] : RAM: 128732MB
[18:34:57] [Program Info/1] : AMP Instance ID: 3bee622d-4d6e-4bad-9f6c-4e156da3e501
[18:34:58] [Core Info/1] : Loaded ADSModule version 2.6.4 by CubeCoders Limited
[18:34:58] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[18:34:58] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[18:34:58] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[18:34:58] [Loader Info/1] : Loaded WebhookPlugin by CubeCoders Limited
[18:34:59] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[18:34:59] [Loader Info/1] : ADSModule requests dependency InstanceManagerPlugin…
[18:35:04] [Loader Info/1] : Loaded InstanceManagerPlugin by CubeCoders Limited
[18:35:04] [Loader Info/1] : ADSModule requests dependency SystemUserManagerPlugin…
[18:35:04] [Loader Info/1] : Loaded SystemUserManagerPlugin by CubeCoders Limited
[18:35:04] [Core Info/1] : Licence Present: AMP Professional Edition - Lifetime Licence
[18:35:04] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[18:35:04] [ADS Info/1] : Metrics server started OK on port 12820
[18:35:04] [Loader Info/1] : ADS startup complete in 45ms
[18:35:04] [System Info/12] : Updating remote source CubeCoders/AMPTemplates:main
[18:35:04] [System Info/12] : Updating existing remote source
No stash entries found.
[18:35:04] [Loader Notice/1] : Using keypair with fingerprint u4pake93LKAcuO3BrbxBWo2WfBflH7v52ISStPZSilc=
[18:35:04] [Loader Info/1] : SFTP Server started on 0.0.0.0:2223
From
4ed6584..b1076f0 main → origin/main
[18:35:05] [Core Info/1] : Webserver started on 0.0.0.0:8080
[18:35:05] [System Info/15] : Checking for AMP updates…
[18:35:05] [System Info/9] : Startup mode is UpdateAndStart.
[18:35:05] [System Info/16] : A new update is available!
[18:35:09] [Core Info/15] : Using default tag: latest
[18:35:18] [Core Info/10] : latest: Pulling from cubecoders/ampbase
[18:35:18] [Core Info/10] : Digest: sha256:b1b7f67f4fad137458b412eb12435502adcb028ea99bb1304892909d39fda4c9
[18:35:18] [Core Info/10] : Status: Image is up to date for cubecoders/ampbase:latest
[18:35:18] [Core Info/15] : docker: Error response from daemon: Conflict. The container name “/AMP_S7DTDNSSDID01” is already in use by container “fd54958c85e9772acc5f2bf4df959d5a0708e17746dc61097fba7a9a6fa00fb0”. You have to remove (or rename) that container to be able to reuse that name.
[18:35:18] [Core Info/15] : Run ‘docker run --help’ for more information
[18:35:23] [Core Info/15] : Using default tag: latest
[18:35:24] [Core Info/15] : latest: Pulling from cubecoders/ampbase
[18:35:24] [Core Info/15] : Digest: sha256:b1b7f67f4fad137458b412eb12435502adcb028ea99bb1304892909d39fda4c9
[18:35:24] [Core Info/15] : Status: Image is up to date for cubecoders/ampbase:latest
[18:35:24] [Core Info/15] : docker.io/cubecoders/ampbase:latest
[18:35:27] [Core Info/16] : 7866e56fea59dbc1acd0c958c431ec54eff1bc6b0e404b9cc1aad921d755946f```
Try running ampinstmgr restart ADS01 and see if that kicks it over
No joy unfortunately. Is there any other info i can get that would be helpful?
Hold up fixed it. My dns record cname was pointing to a target that doesn’t exist anymore. All good now thank you for your help appreciate it.
