Longvinter has the following requirements:
git-lfsis required on Linux. Use of AMP’s Docker feature is recommended for this reason- After creating an instance, install/update the server before changing any configuration settings. Otherwise the server installation will fail (this is simply due to how the server needs to be installed from a GitHub repo on Linux)
(Credit to @Greelan)
