Login Ratelimit doesnt work on Debian 12.5
OS Name/Version: Debian 12.5
Product Name/Version: AMP version and build date: 2.5.0.0 22/03/2024 17:32
  • What are you trying to do?
Testing Bruteforce security, on WAN network with public ip trying to login into my amp with users + passwords, amp is setted to block 5 attemps within 5 minutes
  • What are you expecting to happen?
    IP got blocked / login aborted
  • What is actually happening? (‘Nothing’ is not an acceptable answer!)
    After many login failures i can still login with correct user / passwords without ratelimit or slowdown or anything
  • Install debian 12.5 minimal on VM + apt update & upgrade
  • Run AMP install script
  • expose port to wan (portforward)
  • trying to bruteforce myself trough different WAN ip ex. Mobile Phone or Friends Home PC (different WAN IP)
Using Proxy (NPM) with the correct headers
Reinstalled 3x on fresh VM
Checked AUDIT Log on AMP - the REAL! Wan IP is logged
checked NPM Logs - forwarded correctly
Increased/decreased Login Rate / Limit
tested with proxy and without proxy
tested on SFTP too
this is critical for me, bcs i doesnt want to expose to wan without ratelimit sftp / panel login, dial up ip is dangerous lot of bots bruteforcing my ips - 2 days ago someone trys to brutforce sftp of my minecraft server.
Avoid cross posting please when you’ve already got a github issue open. This has been resolved.
yep, i dont do this anymore, kind of new here, didnt know which way is most maintained bcs i think this is an important security “bug” :slight_smile: im glad its fixed soon
