Login fields and buttons missing when setting branding "Forgot password URL"
OS Name/Version: Debian 11
Product Name/Version: Tested on v2.4.0.10 and FastTrack-20221102-040329
Problem Description: After setting a “Forgot password URL” for my ADS instance the Username,Passwort and login buttons disappear from the login page. As soon as I remove it again, they reappear. All other branding works without Problems. Checked also browser dev tools for any error but nothing except an error with example.com/example.png that is also there when the url is not set.
  • Step 1 Enable Branding
  • Step 2 Set a “Forgot password URL”
  • Step 3 Logout or open Loginpage in a new Window
Without Url:
With Url:
Does anything show up in the browsers F12 error log?
Already posted that info :slight_smile:
Edit: Checked with firefox dev tools as well now (only chrome before) and yes there is an additonal error:
Uncaught (in promise) ReferenceError: href is not defined
    SetModuleInfo https://amp.mcinterface.de/Scripts/UI.js?v=2.4.0.10:729
    APIready https://amp.mcinterface.de/Scripts/AMP.js?v=2.4.0.10:232
    init https://amp.mcinterface.de/Scripts/AMP.js?v=2.4.0.10:171
    async* https://amp.mcinterface.de/Scripts/AMP.js?v=2.4.0.10:41
    jQuery 11
    <anonymous> https://amp.mcinterface.de/Scripts/AMP.js?v=2.4.0.10:37
UI.js:729:58
    AsyncFunctionThrow self-hosted:811
    (Async: async)
    <anonym> https://amp.mcinterface.de/Scripts/AMP.js?v=2.4.0.10:41
    jQuery 11
    <anonym> https://amp.mcinterface.de/Scripts/AMP.js?v=2.4.0.10:37
