AMP.AppModule=MinecraftModule
That is the info from the only instance I have attempted to get running.
Are you using a Wireless network adapter?
I am not. It is hardwired into the router using cat 6 cabling with a 1gb connection. If I run the game server manually without AMP (manual MC setup for example), runs without issue. I purchased AMP so that I could use the control panel to manage multiple servers i run at home… none of them have issues outside of amp… only that annoying issue with no license found inside amp.
Open a command prompt and run:
ampinstmgr deactivate INSTANCENAME
ampinstmgr reactivate INSTANCENAME
Apologies it took so long to respond… work had me.
So… this did not work either. In the end, I had a brand new install of Windows 11 and ran into the same error No Licence.
At this point im dumbfounded why this won’t work.
