Im running a bungeecord network with three additional servers. Can I use my license for all 4 servers or do I have to buy a license for each?
You can yep, the only limit is the total number of game servers (instances) that you’re running.
Though personally I’d suggest using Velocity with modern forwarding if all your servers are newer than 1.13, as Bungeecord is insecure.
https://discourse.cubecoders.com/t/minecraft-proxies-and-you/17673
I was just looking into velocity…thank you. Does AMP support velocity? I haven’t looked yet honestly. thanks
It does yeah, though if the Jar download doesn’t work you just grab it manually from the PaperMC site
