Last Oasis, will not start,
OS Name/Version: Amp Triton v2.3.4.4
Product Name/Version: Last Oasis - 920720
I’ve just installed this. I’ve updated and it successfully updates the last oasis files. However, when I go to start the last oasis server, it loops through verifying install twice. There is very little info on the web about running last oasis servers on linux. Any help would be greatly appreciated.
This is what I get when I try to start the server:
21:05:34
Loading Steam API...OK
21:05:35
Waiting for user info...OK
21:05:36
Update state (0x5) verifying install, progress: 0.00 (0 / 3314228956)
21:05:38
Update state (0x5) verifying install, progress: 7.87 (260992744 / 3314228956)
21:05:40
Update state (0x5) verifying install, progress: 15.95 (528718264 / 3314228956)
21:05:42
Update state (0x5) verifying install, progress: 23.89 (791652953 / 3314228956)
21:05:44
Update state (0x5) verifying install, progress: 31.90 (1057226062 / 3314228956)
21:05:46
Update state (0x5) verifying install, progress: 40.00 (1325761107 / 3314228956)
21:05:48
Update state (0x5) verifying install, progress: 47.90 (1587412963 / 3314228956)
21:05:50
Update state (0x5) verifying install, progress: 55.74 (1847406865 / 3314228956)
21:05:52
Update state (0x5) verifying install, progress: 63.65 (2109603365 / 3314228956)
21:05:54
Update state (0x5) verifying install, progress: 71.68 (2375707846 / 3314228956)
21:05:56
Update state (0x5) verifying install, progress: 79.92 (2648577017 / 3314228956)
21:05:58
Update state (0x5) verifying install, progress: 87.78 (2909316284 / 3314228956)
21:06:00
Update state (0x5) verifying install, progress: 95.74 (3172962522 / 3314228956)
21:06:01
Success! App '920720' fully installed.
If its looping, then it is not finding the executable file to run the server usually. However, seeing as it verified all the installation files, it might be a problem with the configuration. :thinking:
You’ve not filled in the template properly. I don’t see your OS listed.
Know that I have never once been able to get Last Oasis to run under this manager, even in season 4.
Systems Engineer
TWG Hosting
What OS do you want to know Mike, that it’s running on Debian? It’s running on Debian.
The version of Debian would have been nice too :wink:
Anyway, the problem is simply that the developers have changed the filename of the executable at some point.
Either:
A) Delete the instance, fetch the latest configurations (Configuration → Instance Deployment → Fetch Latest), then make a new instance.
B) Stop that instance, edit GenericModule.kvp and change:
App.ExecutableLinux=920720/Mist/Binaries/Linux/MistServer-Linux-Shipping
to
Then start the instance again.
Fantastic. Thank you, sir. And I’m on Debian 10, Buster. A reference to the good ole dog in Toy Story. Which is what I feel like most of the time.
helllo Mike, i am very new to computers and just general “going into files and finding instances”???
uhhhh… how would i do what you said above… my last oasis is missing exe file
