Killing floor 2 workshop issues
OS Name/Version: Windows 10 64bit
Product Name/Version: AMP Release “Phobos” v2.6.2
I havent made a ticket before so apologies if its not formatted correctly.
I’m trying to run custom maps/mods on a Killing floor 2 server and i have followed both guides and different posts to try and figure it out.
I added the workshop id’s into the amp panel and it does download them, at least according to the console, but they wont show up anywhere.
I tried editing the config files of the game where its supposed to be added according to guides and i tried forcing the server to change to the map by logging in as admin and using console commands to force change the map but it says it cant find the map.
If im missing any information let me know.
Loading Steam API...OK
force_install_dir "232130"
18:03:16
18:03:17
Waiting for user info...OK
workshop_download_item 232090 643383080 validate
18:03:18
Downloading item 643383080 ...
Success. Downloaded item 643383080 to "d:\ampdatastore\instances\kf201\killing-floor-2\232130\steamapps\workshop\content\232090\643383080" (147076409 bytes) workshop_download_item 232090 733191110 validate
Downloading item 733191110 ...
Success. Downloaded item 733191110 to "d:\ampdatastore\instances\kf201\killing-floor-2\232130\steamapps\workshop\content\232090\733191110" (673617924 bytes) workshop_download_item 232090 840754106 validate
18:03:19
Downloading item 840754106 ...
Success. Downloaded item 840754106 to "d:\ampdatastore\instances\kf201\killing-floor-2\232130\steamapps\workshop\content\232090\840754106" (309739149 bytes) quit
18:03:20
Unloading Steam API...OK
What’s the normal method for KF2 to use workshop items? The template currently is not set up for it, but might be able to be changed
Try this: Add Workshop Mods to a Killing Floor 2 Server
Don’t use AMP’s Workshop items setting. Seems the server handles mods itself
I’m gonna be honest i havent set up a Killing floor 2 server before, only like csgo and other basic servers. And im new to the AMP tool.
I tried the guide you sent me already where is when i get the successful download in the console but nothing shows up in console or anything about being able to change the map to anything but the official maps.
Usually i figure out these kinks myself but i cant seem to figure this one out.
There seems to be some additional config for maps. See the “manual configuration” section here: Steam Community :: Guide :: How to setup a KF2 Server with custom maps and mods
Tho the AMP config doesn’t seem to cater for custom maps, at least for the Starting Map. It will need to be updated to allow it. Won’t stop you just adding the custom map to the gamecycle
Oh this looks interesting, i havent found this one yet. Will give it a try :slight_smile:
