OS Name/Version: Server 2022 Standard 20348.768
Product Name/Version: AMP Triton V2.3.3.4
Problem Description: On a fresh install of Windows Killing Floor 2 is stuck in a starting state. I have installed the various redestributed binaries (that came with KF2) for dot net etc and I can run the server from the command line. I performed the install of AMP using a standard user account and elevated using an admin account where required during the installation process of AMP.
This what the console looks like in amp -
08:54:22
Update state (0x5) verifying install, progress: 99.26 (27699665243 / 27906035953)
08:54:23
Success! App '232130' fully installed.
Console
08:54:24
Warning, Unknown language extension . Defaulting to INT
08:54:28
Warning, Failed to load 'Texture2D FX_GORE_TEX.FX_Gore_Blend_All_D': Failed to find object 'Texture2D FX_GORE_TEX.FX_Gore_Blend_All_D'
Warning, The Outer object (Package ENG_EngineResources_TEX.Dither) for 'ENG_EngineResources_TEX.Dither.dither_pattern' couldn't be loaded [while loading package ENG_EngineResources_TEX]: Invalid linker index [couldn't load Package ENG_EngineResources_TEX.Dither]?
Warning, Failed to load 'Texture2D ENG_EngineResources_TEX.Dither.dither_pattern': Failed to find object 'Texture2D ENG_EngineResources_TEX.Dither.dither_pattern'
[TWAnalytics::requestInventoryItem] Requesting Item Id: 0 but NULL steamuser
08:54:31
Warning, Failed to load 'ENV_OBJ_TWO_EMIT.StartingWake'! Referenced by 'ENV_OBJ_MESH.BioticsLab.ENV_Tentacle_Animations:AnimSequence_32.AnimNotify_PlayParticleEffect_2' ('Engine.AnimNotify_PlayParticleEffect:PSTemplate').
Warning, Failed to load 'ENV_OBJ_TWO_EMIT': Can't find file for package 'ENV_OBJ_TWO_EMIT' while loading NULL
* Install AMP
* Create KF2 Instance
* Download & Launch vanilla instance of KF2
Deploy new VM, Install fresh copy of AMP. Game Server runs from the command line.
