So I am planning to buy amp because I want to host a few server across 2-4 pc’s that I’m converting to be servers how would u link the panels together and see the servers or what not I am planning on buying the pro version if that is important for hosting from more then one server
It’s very straightforward actually. AMP uses what’s called “Controllers” and “Targets”. Controllers run the show and handle users, authentication, and central management. You add hosts (targets) which actually run the games to the controller by ‘pairing’ them which is a fairly straightforward process with a code.
The controller can then delegate creating and running instances to different targets. All managed from the same place.
Thanks and when I’m setting it up if I need any help I’ll reach out again
