OS Name/Version: Ubuntu Server 23.04
Product Name/Version: AMP 2.4.4
- When I try to start a Minecraft server, it crashes - either immediately or after 10-30mins.
The error is always a coming from the Java Runtime Environment; I noticed that these exceptions are always in relation to SIGSEGV and libjvm.so.
Last error:
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007fac7fd46f10, pid=797, tid=801
# JRE version: OpenJDK Runtime Environment Temurin-17.0.7+7 (17.0.7+7) (build 17.0.7+7)
# Java VM: OpenJDK 64-Bit Server VM Temurin-17.0.7+7 (17.0.7+7, mixed mode, sharing, tiered, compressed oops, compressed class ptrs, g1 gc, linux-amd64)
# Problematic frame:
# V [libjvm.so+0x701f10] oopDesc::size_given_klass(Klass*)+0x0
# Core dump will be written. Default location: Core dumps may be processed with "/usr/share/apport/apport -p%p -s%s -c%c -d%d -P%P -u%u -g%g -- %E" (or dumping to /AMP/Minecraft/core.797)
# If you would like to submit a bug report, please visit:
# https://github.com/adoptium/adoptium-support/issues
Complete Log:
- Install AMP
- Setup a Minecraft instance
- Start the Minecraft server
- Get an error
- Running a Minecraft server instance in a Docker container and w/o a container
- Running various Minecraft and Java versions
- Trying Purpur, Forge and vanilla Minecraft
- Reinstalling Java as well as trying OpenJDK and Oracle
