Issues with new Starbound installation
OS Name/Version: Ubuntu Server 22.04
Product Name/Version: AMP 2.3.2.12
Freshly created Starbound instance is exhibiting strange behavior – when stopping the application is goes into “Stopping…” and never exits cleanly, requiring a force halt to get it to stop.
  • Create new instance and pick StarBound as the game
  • Start instance and application
  • Enter Steam login credentials and steam guard when prompted
  • After application is downloaded start it
  • Attempt to stop application – instead of exiting cleanly is stays stuck in “stopping” until force halted
Console showed that the Steam update worked correctly but the app ID it shows (211820) doesn’t seem right, that’s the Starbound app ID but the Starbound dedicated server app ID is 533830 and that’s what I’d expect to be used here. Unsure if that’s causing the other issues I’m seeing, the server does start and receive clients as expected, it just doesn’t shut down cleanly. I am also able to get the stop to complete by executing this after I trigger the stop:
ampinstmgr view Starbound01
The output of that returns:
[11:39:41] [API:admin Activity] : Stopping the application.
Where it sits indefinitely. Doing a Ctrl+C returns:
[Info] Interrupt caught!
[Info] UniverseServer: Stopping UniverseServer
[Info] UniverseServer: Stopping TCP Server
[Info] Server shutdown gracefully
[Info] Root: Shutting down Root
Console output on first app start (download/verification progress updates removed for brevity):
11:23:19 Steam Console Client (c) Valve Corporation - version 1653101151
-- type 'quit' to exit --
Loading Steam API...OK
11:23:20 Logging in user 'XXXXXXXXXX' to Steam Public...
Enter the current code from your Steam Guard Mobile Authenticator app
11:23:27 Two-factor code:OK
11:23:29 Waiting for client config...OK
Waiting for user info...OK
11:24:10 Update state (0x101) committing, progress: 80.48 (907016434 / 1126979394)
Success! App '211820' fully installed.
Hey @Aaron_Jordan,
I saw your post and wanted to help troubleshoot your Starbound server shutdown issue. Since the server gets stuck in “Stopping…” and requires a force halt, here are a few things to check:
Steps to Try:
  1. Verify Correct App ID Usage – The Starbound client app ID (211820) is being used instead of the dedicated server app ID (533830). Try manually specifying the correct app ID when updating:
    steamcmd +login anonymous +force_install_dir /AMP/Starbound +app_update 533830 validate +quit
  2. Check for Known Issues with AMP v2.3.2.12 – Since this issue was reported in 2022, upgrading to the latest AMP version may resolve the problem.
  3. Manually Stop the Server Using SteamCMD – Instead of stopping the server through AMP, try stopping it manually via SteamCMD:
    steamcmd +login anonymous +app_stop 533830 +quit
  4. Check Logs for Shutdown Errors – Look at the AMP logs and Starbound server logs to see if there are any errors preventing a clean shutdown.
  5. Test with a Fresh Instance – If the issue persists, try creating a new Starbound instance in AMP and see if it shuts down properly.
Let me know if any of these steps help or if the issue persists—I’d be happy to troubleshoot further!
