Issues updating ADS instance from 2.6.3 to 2.6.4 : Locked out of instances because of mismatched versions
OS Name/Version: Windows 10 Pro Build 19045
Product Name/Version: 2.6.3 - 20250926.1
Platform Windows 10 Pro
System Type x86_64
Hardware Platform
CPU Model Intel(R) Core™ i7-7700K CPU @ 4.20GHz
CPU Layout 1S/4C/8T
Installed RAM 16348
Network Mode Standard
Loaded Plugins FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, WebhookPlugin, LocalFileBackupPlugin, CommonCorePlugin, AnalyticsPlugin
Application Name AMPService
Application Version 2.6.3.0
Codename Phobos
Tools Version 2.6.4
Release Stream Mainline
Build Spec Release
Build Date 26/09/2025 12:12
InstanceID 8aa9b382-1052-496d-922e-1b4e711ce71d
Last Executable D:\AMPDatastore\Instances\GarbageZomboid01\AMP.exe
Last Arguments +Core.Webserver.Port “8083” +Core.Webserver.IPBinding “127.0.0.1” +Core.AMP.InstanceID “********-****-****-****-************” +Core.Security.MetricsHMAKKey “**********”
Last Process ID 2848
Hello, I’m currently locked out of all my instances after updating them to version 2.6.4.0, because the ADS version (2.6.3.0) is older than the instances, as ADS fails to update.
So right now, I can’t manage any of my instances apart from start or stop. Hopefully this issue is trivial and i’m missing something. But my competency stops there, so I’ll need your assistance.
In AMP Panel - Support and Updates - Clicking Upgrade this instance - confirm
Panel Stops, then never comes back online (waited for an hour max)
Launching AMP shows ADS still in outdated version
  • Restarting Windows and trying again at each step below
  • Looked up updating guide :
    Tried step 2.2, installing latest AMPsetup.msi and doing it twice with repair option
    Tried Step 5 (.bat script)
  • Running Command in CMD : ampinstmgr upgrade ADS
    gets me this :
[Info/1] AMP Instance Manager v2.6.4 built 14/11/2025 00:07
[Info/1] Stopping Instance: 'ADS01'
[Info/1] Stopping instance ADS01...
[Info/1] Waiting for instance to stop...
[Info/6] Instance ADS01 has stopped.
[Info/6] Upgrading instance ADS01
[Error/9] Failed to extract archive: End of Central Directory record could not be found.
[Error/9] InvalidDataException
[Error/9] [0] (InvalidDataException) : End of Central Directory record could not be found.
[Error/9]    at IO.Compression.ZipArchive.ReadEndOfCentralDirectory()
   at IO.Compression.ZipArchive..ctor(Stream stream, ZipArchiveMode mode, Boolean leaveOpen, Encoding entryNameEncoding)
   at IO.Compression.ZipFile.Open(String archiveFileName, ZipArchiveMode mode, Encoding entryNameEncoding)
   at ModuleShared.Utilities.ExtractZipArchiveAsync(String archivePath, String destinationPath, String currentEntryPath, String newEntryPath, String[] skipFiles, Boolean overwriteExisting, Boolean deleteArchive, RunningTask extractTask, List`1 extractedEntryPaths, Boolean noExecutableMarking, Func`2 allowExtractDelegate)
[Info/9] Upgrade successful
Despite “Upgrade succesful” the version doesn’t update.
Thank you for your time.
I’m replying so that you can share the solution here.
I’m also cross-referencing the Discord post.
Thank BroOtti!
Here’s what worked for me, with help from Mike from the Discord server :
I deleted the Versions folder that was located in D:\AMPDatastore in my case , and ran the command “ampinstmgr upgrade ADS” in CMD.
It worked flawlessly this time, and I didn’t get any error during the CMD process.
Upon launching the ADS instance and accessing web view, every instance is now in the last version and working as expected.
Thank you very much for everyone’s help.
