Operating System: Windows 11 Pro
Product: AMP ‘Deimos’ v2.7 08/03/2026
Virtualization: None
Application: Windrose
Module: Generic
Running in Container: No
Current State: Running
Game Port 7777 UDP not in “Listening” green status
- Stop, update and restart instance
- Update AMP
- Change port number from 7777 to 7779
The instance is running, SFTP is on “Listening” state but the Game Port is none.
Appreciate your help
I am having the exact same issue. I also checked “ampinstmgr ports” and it just said the same thing. TCP Listening, UDP Closed. Not sure how to proceed.
So the game may handle things differently than others. I tested connecting to my server locally and using the “invite code” on amp under “connection info” I was able to connect to the server despite not listening on game port.
I see. I have my other games (Valheim, Palworld etc.) tunneled via playit.gg . Does it mean I do not need to do the tunnel? Or still I am required?
I just tried to get a friend to connect and i think as long as you have Upnp enabled on your router you don’t need a tunnel or portforwarding.
Understood. Really appreciate it mate. I’m going to try and have a test run with my group.
