OS Name/Version: Ubuntu 22.04
Product Name/Version: …what product? I’m trying to play Valheim?
Problem Description: I bought Amp and have logged in and successfully created a Valheim instance. I already have files for a existing server that I want to import, but I can’t find any indication of what I should do next. Is there no start-up guide?
provides syntax highlighting.
You should be able to just use file manager and upload the parts that you need. Make sure everything in the configuration is the same as what you want.
That’s what I’m saying, I don’t know where to upload the files and I’m not sure what even get’s configured, much less what I want. That’s why I asked for a guide, is there no such guide for someone who doesn’t know what they’re doing?
I followed that video but it skips from the end of install to logging into Valheim. How do I know what IP address to use, what port forwarding is necessary, and how do I actually USE the file manager to do anything and where do I even put my .db and .fwl files?
Edit: Ok I figured out where to drop the .fwl and .db files. As far as I can tell it should be working, but when I manage the instance and use the connect to application button it doesn’t work. It asks for and accepts the password for the world and launches valheim, has me choose a character, then fails to connect. Any ideas?
Also, will others from outside my local network just be using my router’s public IP and the 2456/2457 ports to connect?
My router would not let me forward the port to my router itself, saying invalid IP. What should be the internal IP I’m forwarding it to, the computer I’m running amp from? I think I have port forwarding set up but it still won’t work, neither 2456 or 2457. It tries to, asks for password, then fails to connect. Same result trying to connect from within amp or directly from within game. Can’t find the game on the list of servers.
