Is it possible to Pin Threads
I was looking at getting Amp and cant find any info on pinning threads. Is there a way to pin threads manually per instance?
Yes, go to Instance Settings (Pencil Icon) → Container Settings and “CPU Set”
This requires that you’re using a container (Docker / Podman)
Thanks Mike just to be clear I can assign a specific numbered cpu thread to a instance?
Yes, it’s explained right there in that part of the configuration.
