IP chnaged, how do I access GUI?
OS Name/Version: UnRaid OS; Debian Headless VM
Product Name/Version: AMP?
Problem Description: I had to swap the port my server was plugged into at the router which has shifted IP addresses. I am trying to figure out what AMPs new IP is via linux command line but haven’t had any luck. Is there a specific command? all I can find is “ampinstmgr” but that doesn’t seem to look at amp as a whole but rather just specific instances. Is there a command line documentation somewhere?
edit:
been trying to figure it out. Is it just the IP of the Debian install plus the port?
It’s just your servers IP on whatever port AMP is listening on (Default 8080 for non-HTTPS)
Great thanks closing this as I was able to find the IP address.
