Insurgency Sandstorm failed to initiate instance
INSURGENCY SANDSTORM INSTANCE FAIL.
OS Name/Version: Windows 11 24H2
Product Name/Version: Insurgency Sandstorm
Problem Description: Not able to complete initial instance installation.
Stopped stop_circle
Console
13:06:28
LogEOSAntiCheat: Display: ServerBeginSession: Result : (EOS_Success)
13:06:29
LogGameStatsServer: Error: LoginResult: Code=403 Body=token_invalid
13:06:33
LogGameMode: Display: State: GameStarting -> PreRound
LogActor: Warning: SetReplicates called on non-initialized actor INSSoldier_2147481905. Directly setting bReplicates is the correct procedure for pre-init actors.
LogActor: Warning: SetReplicates called on non-initialized actor INSSoldier_2147481902. Directly setting bReplicates is the correct procedure for pre-init actors.
LogSession: Display: AINSGameSession::HandleMatchHasStarted
LogOnlineSession: Warning: STEAM (NWI): Can't start an online session (GameSession) in state Creating
LogOnlineGame: Display: OnStartSessionComplete GameSession bSuccess: 0
LogGameMode: Display: Starting round replay recording, filename: "Farmhouse_2025.08.27-17.06.33", name: "Farmhouse-Range-"
LogINSAssetManager: Display: Loading scenario asset 'Scenario_Farmhouse_Range' (path: /Game/Game/Scenarios/Training/Scenario_Farmhouse_Range.Scenario_Farmhouse_Range)...
LogSession: Display: AINSGameSession::HandleMatchPreRound
LogSpawner: Error: ASpawnerBase: Error spawning pawns, invalid AI controller. TeamId = 255, Team = nullptr, PlayerClass = nullptr
LogGameMode: Display: State: PreRound -> RoundActive
LogGameMode: Display: High priority async loading DISABLED
LogGameMode: Warning: ACTIVITY: Unable to update match status
LogSession: Display: AINSGameSession::HandleMatchRoundActive
LogINSAssetManager: Display: Loading scenario factions...
LogINSAssetManager: Display: Loading 673 scenario assets...
LogINSAssetManager: Display: Scenario loading complete.
LogHttpReplay: Error: FHttpNetworkReplayStreamer::HttpStartUploadingFinished. FAILED, Response code: 401, Extra info: URL: https://replays.newworldinteractive.com/client_14/replay/farmhouse_2025.08.27-17.06.33?app=Insurgency&version=2&cl=349922&friendlyName=Farmhouse-Range-, Verb: POST, Content-Type: application/json, User-Agent: Insurgency/Unknown-CL-349922 Windows/10.0.26100.1.256.64bit, Content-Length: 0, Expect:
LogActor: Warning: SetReplicates called on non-initialized actor BP_Firearm_M2HB_C_2147481504. Directly setting bReplicates is the correct procedure for pre-init actors.
LogActor: Warning: SetReplicates called on non-initialized actor BP_Firearm_DShK_C_2147481478. Directly setting bReplicates is the correct procedure for pre-init actors.
LogDemo: Error: UDemoNetDriver::TickFlush: ReplayStreamer ERROR: ServiceUnavailable
LogHttpReplay: Warning: FHttpNetworkReplayStreamer::StopStreaming. Called while existing StartStreaming request wasn't finished
LogOnlineGame: Display: OnStartSessionComplete GameSession bSuccess: 1
LogAI: Warning: UINSAIDirector: Purging empty squad INSAISquad_2147481835
LogAI: Warning: UINSAIDirector: Purging empty squad INSAISquad_2147481530
LogAI: Warning: UINSAIDirector: Purging empty squad INSAISquad_2147481502
LogAI: Warning: UINSAIDirector: Purging empty squad INSAISquad_2147481476
13:06:38
13:06:42
LogOnline: Warning: OSS: Async task 'FOnlineAsyncTaskSteamCreateServer bWasSuccessful: 0' failed in 15.021701 seconds
LogSession: Display: OnCreateSessionComplete: Session: (GameSession) Result: (0)
13:06:47
13:07:16
13:07:53
13:08:24
13:09:00
13:09:34
  • Step 1 clicked drop down, selected insurgency sandstorm
  • Step 2 turned on all ports required for port forwarding on router
  • Step 3 waited over 2hrs before I finally checked console to see that it was giving errors (stuck in “Starting” on the UI).
Actions taken to resolve so far: Googled errors, and all it basically gave me was it’s an authentication issue.
