Instances will not run
The Following is the specs of server followed by 1 of the logs I found:
OS: Windows Server 2022
OS Name/Version:
Windows Server 2022
Product Name/Version:
AMP Release “Triton” v2.3.4, built 16/06/2022 16:08
Ok I am having problems. One instance that I install (Satisfactory) displays “Application State: Unable to run” and just to check I set up instance (Minecraft) which this one shuts right down immediately. I tried multiple times to install AMP using the “Windows Server” and “Server Core” guides. I am using the amp user with admin group rights. I think I am over looking something or maybe it just does not like me. Anyone able help me out to get AMP to work for me?
in Info]       : Starting AMPService version 2.3.4.0 (Triton), built 16/06/2022 16:08
[23:24:27] [GSMyAdmin Info]       : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[23:24:28] [GSMyAdmin Warning]    : Current time zone is set to Central America Standard Time - Servers should ideally be UTC to avoid time-zone related issues
[23:24:28] [GSMyAdmin Info]       : OS: Windows / x86_64
[23:24:28] [GSMyAdmin Info]       : CPU: Intel(R) Xeon(R) Silver 4123 CPU @ 3.00GHz (8C/16T)
[23:24:28] [GSMyAdmin Info]       : AMP Instance ID: 14c431a6-eb8f-4a5f-8fa6-c8f87298c4f8
[23:24:28] [GSMyAdmin Info]       : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[23:24:28] [GSMyAdmin Info]       : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[23:24:28] [GSMyAdmin Info]       : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[23:24:28] [GSMyAdmin Info]       : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[23:24:28] [GSMyAdmin Info]       : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[23:24:28] [GSMyAdmin Info]       : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[23:24:28] [GSMyAdmin Info]       : ADSModule requests dependency InstanceManagerPlugin...
[23:24:29] [GSMyAdmin Info]       : Loaded InstanceManagerPlugin version 1.0.0.0 by CubeCoders Limited
[23:24:29] [GSMyAdmin Info]       : ADSModule requests dependency SystemUserManagerPlugin...
[23:24:29] [GSMyAdmin Info]       : Loaded SystemUserManagerPlugin version 1.0.0.0 by CubeCoders Limited
[23:24:29] [GSMyAdmin Info]       : Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
[23:24:29] [Core Info]            : Metrics server started OK on port 12820
[23:24:30] [ADS Info]             : Updating remote source CubeCoders/AMPTemplates
[23:24:30] [GSMyAdmin Notice]     : Using keypair with fingerprint 6ToNHgGmjlDFFxiYwtPygau2GJ/W1xNo3ZsLlDibo2U=
[23:24:30] [FileManager Info]     : SFTP Server started on 0.0.0.0:2223
[23:24:30] [GSMyAdmin Info]       : Websockets are enabled.
Already up to date.
[23:24:30] [WebServer Warning]    : RouterTimer@10Hz with 2 jobs started
[23:24:30] [GSMyAdmin Info]       : Webserver started on http://0.0.0.0:8080
[23:24:30] [GSMyAdmin Info]       : Checking for AMP updates...
[23:24:31] [GSMyAdmin Info]       : AMP is up-to-date.
[23:24:48] [InstanceManager:sgtkrazy Info] : Using cached archive: D:\AMPDatastore\Instances\AMPCache-2340.zip
[23:24:55] [InstanceManager:sgtkrazy Info] : Waiting for AMP instance to start...
[23:24:55] [System:sgtkrazy Notice] : AMP instance Satisfactory01 is now running.
[23:25:26] [ADS:sgtkrazy Activity] : Managed remote instance Satisfactory01 at http://127.0.0.1:8081/
[23:25:26] [GSMyAdmin:sgtkrazy Activity] : Authentication token for sgtkrazy requested by ManageInstance on behalf of sgtkrazy
[23:30:26] [ADS:sgtkrazy Activity] : Managed remote instance Satisfactory01 at http://127.0.0.1:8081/
[23:30:26] [GSMyAdmin:sgtkrazy Activity] : Authentication token for sgtkrazy requested by ManageInstance on behalf of sgtkrazy
[23:31:33] [InstanceManager:sgtkrazy Info] : Using cached archive: D:\AMPDatastore\Instances\AMPCache-2340.zip
[23:31:37] [ADS:sgtkrazy Activity] : Managed remote instance Satisfactory01 at http://127.0.0.1:8081/
[23:31:37] [GSMyAdmin:sgtkrazy Activity] : Authentication token for sgtkrazy requested by ManageInstance on behalf of sgtkrazy
[23:31:39] [InstanceManager:sgtkrazy Info] : Waiting for AMP instance to start...
[23:31:39] [System:sgtkrazy Notice] : AMP instance Minecraft01 is now running.
[23:31:50] [InstanceManager:sgtkrazy Activity] : Instance Minecraft01 has stopped.
[23:31:50] [ADS:sgtkrazy Info]    : ADS logged stopped instance Minecraft01 - exit code -1 (CATASTROPHIC_FAILURE)
[23:32:38] [ADS:sgtkrazy Activity] : Managed remote instance Satisfactory01 at http://127.0.0.1:8081/
[23:32:38] [GSMyAdmin:sgtkrazy Activity] : Authentication token for sgtkrazy requested by ManageInstance on behalf of sgtkrazy
[23:32:51] [ADS:sgtkrazy Activity] : Managed remote instance Satisfactory01 at http://127.0.0.1:8081/
[23:32:51] [GSMyAdmin:sgtkrazy Activity] : Authentication token for sgtkrazy requested by ManageInstance on behalf of sgtkrazy
[23:32:59] [InstanceManager:sgtkrazy Info] : Stopping instance Satisfactory01...
[23:32:59] [InstanceManager:sgtkrazy Info] : Requesting soft-stop...
[23:32:59] [InstanceManager:sgtkrazy Info] : Waiting for instance to stop...
[23:33:18] [InstanceManager:sgtkrazy Info] : Waiting for AMP instance to start...
[23:33:18] [System:sgtkrazy Notice] : AMP instance Minecraft01 is now running.
[23:33:19] [ADS:sgtkrazy Activity] : Managed remote instance Minecraft01 at http://127.0.0.1:8082/
[23:33:19] [GSMyAdmin:sgtkrazy Activity] : Authentication token for sgtkrazy requested by ManageInstance on behalf of sgtkrazy
[23:33:20] [InstanceManager:sgtkrazy Info] : Soft-stop request was ignored after waiting for 20 seconds, force stopping...
[23:33:20] [InstanceManager:sgtkrazy Activity] : Instance Satisfactory01 has stopped.
[23:33:20] [InstanceManager:sgtkrazy Info] : Instance Satisfactory01 has stopped.
[23:33:20] [InstanceManager:sgtkrazy Activity] : Instance Minecraft01 has stopped.
[23:33:20] [ADS:sgtkrazy Info]    : ADS logged stopped instance Minecraft01 - exit code 32 (NO_LICENCE)
[23:33:20] [ADS:sgtkrazy Info]    : Reactivating instance Minecraft01...
[23:33:23] [InstanceManager:sgtkrazy Info] : Waiting for AMP instance to start...
[23:33:23] [System:sgtkrazy Notice] : AMP instance Minecraft01 is now running.
[23:33:55] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:33:55] [ADS:Anonymous Error]  : HttpRequestException
[23:33:55] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:33:55] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
   at ADSModule.WebMethods.<Servers>()
[23:33:55] [ADS:Anonymous Error]  : WebException
[23:33:55] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:33:55] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
   at Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar)
[23:33:55] [ADS:Anonymous Error]  : SocketException
[23:33:55] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:33:55] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
   at Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
   at Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
[23:33:56] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:33:56] [ADS:Anonymous Error]  : HttpRequestException
[23:33:56] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:33:56] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:33:56] [ADS:Anonymous Error]  : WebException
[23:33:56] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:33:56] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:33:56] [ADS:Anonymous Error]  : SocketException
[23:33:56] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:33:56] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:33:57] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:33:57] [ADS:Anonymous Error]  : HttpRequestException
[23:33:57] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:33:57] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:33:57] [ADS:Anonymous Error]  : WebException
[23:33:57] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:33:57] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:33:57] [ADS:Anonymous Error]  : SocketException
[23:33:57] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:33:57] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:33:58] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:33:58] [ADS:Anonymous Error]  : HttpRequestException
[23:33:58] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:33:58] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:33:58] [ADS:Anonymous Error]  : WebException
[23:33:58] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:33:58] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:33:58] [ADS:Anonymous Error]  : SocketException
[23:33:58] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:33:58] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:33:59] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:33:59] [ADS:Anonymous Error]  : HttpRequestException
[23:33:59] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:33:59] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:33:59] [ADS:Anonymous Error]  : WebException
[23:33:59] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:33:59] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:33:59] [ADS:Anonymous Error]  : SocketException
[23:33:59] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:33:59] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:34:00] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:34:00] [ADS:Anonymous Error]  : HttpRequestException
[23:34:00] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:34:00] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:34:00] [ADS:Anonymous Error]  : WebException
[23:34:00] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:34:00] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:34:00] [ADS:Anonymous Error]  : SocketException
[23:34:00] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:34:00] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:34:14] [InstanceManager:sgtkrazy Info] : Waiting for AMP instance to start...
[23:34:14] [System:sgtkrazy Notice] : AMP instance Satisfactory01 is now running.
[23:34:14] [ADS:sgtkrazy Activity] : Managed remote instance Satisfactory01 at http://127.0.0.1:8081/
[23:34:14] [GSMyAdmin:sgtkrazy Activity] : Authentication token for sgtkrazy requested by ManageInstance on behalf of sgtkrazy
[23:34:29] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:34:29] [ADS:Anonymous Error]  : HttpRequestException
[23:34:29] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:34:29] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:34:29] [ADS:Anonymous Error]  : WebException
[23:34:29] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:34:29] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:34:29] [ADS:Anonymous Error]  : SocketException
[23:34:29] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:34:29] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:34:30] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:34:30] [ADS:Anonymous Error]  : HttpRequestException
[23:34:30] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:34:30] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:34:30] [ADS:Anonymous Error]  : WebException
[23:34:30] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:34:30] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:34:30] [ADS:Anonymous Error]  : SocketException
[23:34:30] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:34:30] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:34:31] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:34:31] [ADS:Anonymous Error]  : HttpRequestException
[23:34:31] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:34:31] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:34:31] [ADS:Anonymous Error]  : WebException
[23:34:31] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:34:31] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:34:31] [ADS:Anonymous Error]  : SocketException
[23:34:31] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:34:31] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:34:32] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:34:32] [ADS:Anonymous Error]  : HttpRequestException
[23:34:32] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:34:32] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:34:32] [ADS:Anonymous Error]  : WebException
[23:34:32] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:34:32] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:34:32] [ADS:Anonymous Error]  : SocketException
[23:34:32] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:34:32] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:34:33] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:34:33] [ADS:Anonymous Error]  : HttpRequestException
[23:34:33] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:34:33] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:34:33] [ADS:Anonymous Error]  : WebException
[23:34:33] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:34:33] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:34:33] [ADS:Anonymous Error]  : SocketException
[23:34:33] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:34:33] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:34:34] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:34:34] [ADS:Anonymous Error]  : HttpRequestException
[23:34:34] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:34:34] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:34:34] [ADS:Anonymous Error]  : WebException
[23:34:34] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:34:34] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:34:34] [ADS:Anonymous Error]  : SocketException
[23:34:34] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:34:34] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:34:49] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetAPISpec) - retried 10 times : An error occurred while sending the request.
[23:34:49] [ADS:Anonymous Error]  : HttpRequestException
[23:34:49] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:34:49] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:34:49] [ADS:Anonymous Error]  : WebException
[23:34:49] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:34:49] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:34:49] [ADS:Anonymous Error]  : SocketException
[23:34:49] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:34:49] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:35:00] [InstanceManager Activity] : Instance Satisfactory01 has stopped.
[23:35:00] [ADS Info]             : ADS logged stopped instance Satisfactory01 - exit code 32 (NO_LICENCE)
[23:35:00] [ADS Info]             : Reactivating instance Satisfactory01...
[23:35:02] [InstanceManager Info] : Waiting for AMP instance to start...
[23:35:02] [System Notice]        : AMP instance Satisfactory01 is now running.
[23:35:03] [System Error]         : Exception executing global interval tick. Collection was modified; enumeration operation may not execute.
[23:35:03] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:35:03] [ADS:Anonymous Error]  : HttpRequestException
[23:35:03] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:35:03] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:35:03] [ADS:Anonymous Error]  : WebException
[23:35:03] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:35:03] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:35:03] [ADS:Anonymous Error]  : SocketException
[23:35:03] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:35:03] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:35:04] [System:Anonymous Error] : Failure to make API call to Satisfactory01 (http://127.0.0.1:8081/API/Core/GetUpdates) - retried 10 times : An error occurred while sending the request.
[23:35:04] [ADS:Anonymous Error]  : HttpRequestException
[23:35:04] [ADS:Anonymous Error]  : [0] (HttpRequestException) : An error occurred while sending the request.
[23:35:04] [ADS:Anonymous Error]  :    at ADSModule.WebMethods.<MakeInstanceRequest>()
[23:35:04] [ADS:Anonymous Error]  : WebException
[23:35:04] [ADS:Anonymous Error]  : [1] (WebException) : Unable to connect to the remote server
[23:35:04] [ADS:Anonymous Error]  :    at Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
[23:35:04] [ADS:Anonymous Error]  : SocketException
[23:35:04] [ADS:Anonymous Error]  : [2] (SocketException) : No connection could be made because the target machine actively refused it 127.0.0.1:8081
[23:35:04] [ADS:Anonymous Error]  :    at Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
[23:37:51] [ADS:sgtkrazy Activity] : Managed remote instance Satisfactory01 at http://127.0.0.1:8081/
[23:37:51] [GSMyAdmin:sgtkrazy Activity] : Authentication token for sgtkrazy requested by ManageInstance on behalf of sgtkrazy
[23:42:04] [ADS:sgtkrazy Activity] : Managed remote instance Satisfactory01 at http://127.0.0.1:8081/
[23:42:04] [GSMyAdmin:sgtkrazy Activity] : Authentication token for sgtkrazy requested by ManageInstance on behalf of sgtkrazy
Check the logs of the instances themselves (right click on an instance, view logs). Possibly a licence issue, or maybe required dependencies are not installed
@Greelan Thank you! I figured I was over looking something which I was. Wasn’t necessarily a license issue, but looking at the instance log found a dependency was missing. Again thank you for pointing me in the right area to look.
