OS Name/Version: Ubuntu 24.04
Product Name/Version: AMP 2.5.1.2
Problem Description: AMP backend is not available on new Ubuntu install. When I click start on the web instance it shows attempting to start but never seems successfull. No instances are shown running on the server.
provides syntax highlighting.
- Step 1: Install Ubuntu and AMP with Docker option enabled and HTTPS disabled.
- Step 2: Go to local homeserver address and attempt to start new instance.
Reinstalled OS and AMP. Restarted AMP Instance Manager and Rebooted.
[06:41:58] [Core Info/1] : Starting AMP version 2.5.1.2 (Callisto), built 24/07/2024 21:33
[06:41:58] [Core Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[06:41:58] [Core Warning/1] : Current time zone is set to CST - It is recommended you switch to UTC+0 to avoid time-zone related issues
[06:41:58] [Core Info/1] : OS: Linux / x86_64
[06:41:58] [Core Info/1] : CPU: Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz (6C/6T)
[06:41:58] [Core Info/1] : RAM: 15925MB
[06:41:58] [Core Info/1] : AMP Instance ID: da14b389-db81-41bc-89b9-279010ff5f35
[06:41:58] [Loader Info/1] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[06:41:58] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[06:41:58] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[06:41:58] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[06:41:58] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[06:41:58] [Loader Info/1] : ADSModule requests dependency InstanceManagerPlugin...
[06:41:58] [Loader Info/1] : Loaded InstanceManagerPlugin by CubeCoders Limited
[06:41:58] [Loader Info/1] : ADSModule requests dependency SystemUserManagerPlugin...
[06:41:58] [Loader Info/1] : Loaded SystemUserManagerPlugin by CubeCoders Limited
[06:41:58] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[06:41:59] [Core Info/1] : Metrics server started OK on port 12820
[06:41:59] [ADS Info/1] : ADS startup complete in 100ms
[06:41:59] [ADS Info/8] : Updating remote source CubeCoders/AMPTemplates
[06:41:59] [ADS Info/8] : Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
[06:41:59] [FileManager Notice/1] : Using keypair with fingerprint 6glp0efdG6qO96LetfXCfrLBSlmy1E2vDEKRe6mFRkU=
[06:41:59] [FileManager Info/1] : SFTP Server started on 0.0.0.0:2223
[06:41:59] [Webserver Info/1] : Websockets are enabled.
Already up to date.
[06:42:00] [Logger Info/14] : RouterTimer@10Hz with 2 jobs started
[06:42:00] [Webserver Info/1] : Webserver started on http://0.0.0.0:8080
[06:42:00] [Core Info/1] : Checking for AMP updates...
[06:42:00] [Core Info/6] : Startup mode is StartApplication.
[06:42:00] [Core Info/10] : AMP is up to date.
[06:42:04] [InstanceManager Info/12] : dbc01692f5eb3df439f17aa550ab75f2182c87f518ed63ad206325ef46a94e03
[06:42:44] [InstanceManager Error/9] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:48:18] [InstanceManager:ampadmin Info/18] : a0f0214489b476e80e74704a4579fc4ba3fc7309e0bdf23bf9e3e4fdaea453ab
[06:48:20] [InstanceManager Error/9] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:48:26] [InstanceManager Error/10] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:48:32] [InstanceManager Error/19] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:48:38] [InstanceManager Error/16] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:48:44] [InstanceManager Error/18] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:48:50] [InstanceManager Error/16] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:48:56] [InstanceManager Error/10] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:49:02] [InstanceManager Error/12] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:49:08] [InstanceManager Error/20] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:49:14] [InstanceManager Error/16] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:49:20] [InstanceManager Error/6] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:49:26] [InstanceManager Error/17] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:49:32] [InstanceManager Error/8] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:49:38] [InstanceManager Error/11] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:49:44] [InstanceManager Error/9] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:49:50] [InstanceManager Error/12] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:49:56] [InstanceManager Error/11] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:50:02] [InstanceManager Error/10] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:50:08] [InstanceManager Error/8] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:50:14] [InstanceManager Error/17] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:50:20] [InstanceManager Error/11] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:50:26] [InstanceManager Error/20] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:50:32] [InstanceManager Error/11] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:50:35] [FileManager Activity/18] : Downloaded file __VDS__Zomboid101/AMP_Logs/AMPLOG 2024-07-31 06-48-19.log (Direct mode)
[06:50:38] [InstanceManager Error/18] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:50:44] [InstanceManager Error/10] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:50:50] [InstanceManager Error/20] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:50:56] [InstanceManager Error/10] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:51:02] [InstanceManager Error/11] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:51:08] [InstanceManager Error/11] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:51:14] [InstanceManager Error/16] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:51:20] [InstanceManager Error/16] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:51:26] [InstanceManager Error/8] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:51:32] [InstanceManager Error/17] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:51:38] [InstanceManager Error/20] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:51:44] [InstanceManager Error/11] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:51:50] [InstanceManager Error/18] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:51:56] [InstanceManager Error/12] : LIM - Failure to make API call to Zomboid101: Connection refused
[06:52:01] [FileManager Activity/8] : Downloaded file __VDS__ADS01/AMP_Logs/AMPLOG 2024-07-31 06-41-57.log (Direct mode)
02:03:44
02:03:50
02:03:56
02:04:02
02:04:08
02:04:14
02:04:20
02:04:26
02:04:32
02:04:38
02:04:44
