Instances not running after update RCON error
OS Name/Version: [Ubuntu-2404-noble-amd64-base]
Product Name/Version: AMP Release “Phobos” v2.6.0.8, built 24/01/2025 10:16
servers are not starting or showing up after upgrading AMP im always geting RCON errors
relatet logs:
[08:42:50] [System:ray Error/7]   : Source RCON failed to connect:
Connection refused.
[08:42:50] [RCON:ray Info/13]     : Source RCON disconnecting...
[08:42:51] [RCON:ray Info/13]     : Source RCON disconnected
[08:42:56] [System:ray Error/13]  : Source RCON failed to connect:
Connection refused.
[08:42:56] [RCON:ray Info/9]      : Source RCON disconnecting...
[08:42:57] [RCON:ray Info/9]      : Source RCON disconnected
[08:43:02] [System:ray Error/7]   : Source RCON failed to connect:
Connection refused.
[08:43:02] [RCON:ray Info/9]      : Source RCON disconnecting...
[08:43:03] [RCON:ray Info/9]      : Source RCON disconnected
[08:43:08] [System:ray Error/7]   : Source RCON failed to connect:
Connection refused.
[08:43:08] [RCON:ray Info/7]      : Source RCON disconnecting...
[08:43:09] [RCON:ray Info/7]      : Source RCON disconnected
  • update amp to newest version
  • Step 2
  • Step 3
one instance got fixend by coping the save files to a new instance but that does not work on the other instances
Try and reset the RCON admin password in the settings and restart the server
Sadly this does not fix the problem after updating the admin pw and updating the instance i get this in the logs:
game / instance is: ARK: Survival Ascended (minmal)
[18:33:06] [Program Info/1]       : Starting AMP version 2.6.0.8 (Phobos), built 24/01/2025 10:16
[18:33:06] [Program Info/1]       : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[18:33:06] [Program Warning/1]    : Current time zone is set to Central European Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[18:33:06] [Program Info/1]       : OS: Linux / x86_64
[18:33:06] [Program Info/1]       : CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz (8C/16T)
[18:33:06] [Program Info/1]       : RAM: 128722MB
[18:33:06] [Program Info/1]       : AMP Instance ID: 885eac29-34fb-4547-b8f6-ac11e9d63509
[18:33:06] [Core Info/1]          : Loaded GenericModule version 2.6.0.8 by CubeCoders Limited
[18:33:06] [Core Info/1]          : Metrics publishing is enabled at udp://localhost:12820.
[18:33:06] [Loader Info/1]        : Loaded FileManagerPlugin by CubeCoders Limited
[18:33:07] [Loader Info/1]        : Loaded EmailSenderPlugin by CubeCoders Limited
[18:33:07] [Loader Info/1]        : Loaded WebRequestPlugin by CubeCoders Limited
[18:33:07] [Loader Info/1]        : Loaded LocalFileBackupPlugin by CubeCoders Limited
[18:33:07] [Loader Info/1]        : Loaded CommonCorePlugin by CubeCoders Limited
[18:33:07] [Loader Info/1]        : Loaded AnalyticsPlugin by CubeCoders Limited
[18:33:07] [System Error/7]       : Missing plugin/assembly: MaxMind.Db (/home/amp/.ampdata/instances/Center01/Plugins/MaxMind.Db/MaxMind.Db.dll) for
[18:33:07] [Loader Info/1]        : GenericModule requests dependency steamcmdplugin...
[18:33:07] [Loader Info/1]        : Loaded steamcmdplugin by CubeCoders Limited
[18:33:07] [Loader Info/1]        : GenericModule requests dependency RCONPlugin...
[18:33:07] [Loader Info/1]        : Loaded RCONPlugin by CubeCoders Limited
[18:33:07] [Core Info/1]          : Licence Present: AMP Professional Edition - Lifetime Licence
[18:33:07] [Loader Notice/1]      : Using keypair with fingerprint (some stuff here who looks private)
[18:33:07] [Loader Info/1]        : SFTP Server started on 0.0.0.0:2227
[18:33:08] [Core Info/1]          : Webserver started on http://127.0.0.1:8083
[18:33:08] [System Info/12]       : Checking for AMP updates...
[18:33:08] [System Info/10]       : AMP is up to date.
[18:33:12] [System Activity/10]   : Authentication attempt for user ray from 127.0.0.1
[18:33:12] [System Activity/10]   : Authentication success
[18:33:15] [Core:ray Activity/10] : Starting the application.
fsync: up and running.
[Success]: Detected Server: ArkAscendedServer.exe
[Success]: Detected Api: AsaApi.dll
[18:33:18] [System:ray Warning/10] : Slow method invocation: Start took 3068ms to complete.
[18:33:18] [System:ray Warning/10] : Slow response: Core.Start took 3069ms to complete.
[Success]: Loader Completed, Reason: Success
[18:33:35] [System:ray Error/17]  : Source RCON failed to connect:
Connection refused.
[18:33:35] [RCON:ray Info/9]      : Source RCON disconnecting...
[18:33:36] [RCON:ray Info/9]      : Source RCON disconnected
[18:33:41] [System:ray Error/9]   : Source RCON failed to connect:
Connection refused.
[18:33:41] [RCON:ray Info/17]     : Source RCON disconnecting...
[18:33:42] [RCON:ray Info/17]     : Source RCON disconnected
[18:33:47] [System:ray Error/9]   : Source RCON failed to connect:
Connection refused.
[18:33:47] [RCON:ray Info/17]     : Source RCON disconnecting...
[18:33:48] [RCON:ray Info/17]     : Source RCON disconnected
[18:33:53] [System:ray Error/9]   : Source RCON failed to connect:
Connection refused.
[18:33:53] [RCON:ray Info/17]     : Source RCON disconnecting...
[18:33:54] [RCON:ray Info/17]     : Source RCON disconnected
[18:33:59] [System:ray Error/17]  : Source RCON failed to connect:
Connection refused.
[18:33:59] [RCON:ray Info/17]     : Source RCON disconnecting...
[18:34:00] [RCON:ray Info/17]     : Source RCON disconnected
[18:34:05] [System:ray Error/17]  : Source RCON failed to connect:
Connection refused.
[18:34:05] [RCON:ray Info/17]     : Source RCON disconnecting...
[18:34:06] [RCON:ray Info/17]     : Source RCON disconnected
[18:34:11] [System:ray Error/17]  : Source RCON failed to connect:
Connection refused.
[18:34:11] [RCON:ray Info/17]     : Source RCON disconnecting...
[18:34:12] [RCON:ray Info/17]     : Source RCON disconnected
[18:34:17] [System:ray Error/10]  : Source RCON failed to connect:
Connection refused.
[18:34:17] [RCON:ray Info/17]     : Source RCON disconnecting...
[18:34:18] [RCON:ray Info/17]     : Source RCON disconnected
What happens if you reset the RCON password, stop the instance from the main panel, and then start it again?
Error / problem got fixed
after changing from api launcher to vanilla launcher it got fixed
