Instances disappeared after updating to AMP 2.4.7
After updating to AMP v2.4.7, the instances are no longer displaying. Console logs show the below error
Assembly Newtonsoft.Json was loaded for Core via fallback handler, check plugin dependencies.
Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
Loaded FileManagerPlugin by CubeCoders Limited
Loaded EmailSenderPlugin by CubeCoders Limited
Loaded WebRequestPlugin by CubeCoders Limited
Loaded LocalFileBackupPlugin by CubeCoders Limited
Loaded CommonCorePlugin by CubeCoders Limited
ADSModule requests dependency InstanceManagerPlugin…
13:30:41
Failed to read instance data: Newtonsoft.Json.JsonReaderException: Unexpected character encountered while parsing value: [. Path ‘[0].ExtraContainerPackages’, line 3, position 31. at Newtonsoft.Json.JsonTextReader.ReadStringValue(ReadType readType) at Newtonsoft.Json.JsonTextReader.ReadAsString() at Newtonsoft.Json.JsonReader.ReadForType(JsonContract contract, Boolean hasConverter) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateList(IList list, JsonReader reader, JsonArrayContract contract, JsonProperty containerProperty, String id) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateList(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, Object existingValue, String id) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent) at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType) at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings) at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings) at InstanceManagerPlugin.LocalInstanceManager.GetLocalInstances(String AlternateDefsPath)
Loaded InstanceManagerPlugin by CubeCoders Limited
ADSModule requests dependency SystemUserManagerPlugin…
Loaded SystemUserManagerPlugin by CubeCoders Limited
Licence Present: AMP Standard Edition
13:30:42
Loaded steamcmdplugin by CubeCoders Limited
13:30:43
ADS startup complete in 1326ms
13:30:44
Using keypair with fingerprint JGJXmkU3CjqYxeguLAm0kiPEa7dnMm4qLmjxlN6Yqgg=
Websockets are enabled.
13:30:46
Migrated 0 legacy permissions for Default
Migrated 0 legacy permissions for Super Admins
RouterTimer@10Hz with 2 jobs started
Checking for AMP updates…
Startup mode is StartApplication.
13:30:47
AMP is up to date.
This has been fixed, re-update. The instances will re-appear.
The update resolved the issue. Thanks!
