Instance was not created correctly
I have installed and activated AMP as described. If I now create an instance. It says that it will be created. It is then displayed to me. However, I can neither start it nor are there any files in the instance folder
Übersetzt mit DeepL Translate anytime, anywhere with DeepL apps and extensions.
OS : Debian 12
Version : current
You appear to have pasted something random rather than what you intended to paste? Also you deleted the template and haven’t provided the required information. Please follow the original template when making posts.
I don’t know what you mean. This system here is too complicated for me:(
When you created the post, you didn’t follow the template (which is why your post is no getting much response) - have you tried again?
