OS Name/Version: Debian 13
Product Name/Version: AMP, Version: 2.6.4 - 20251114.1
Problem Description: Instance of Factorio not starting / updating
provides syntax highlighting.
- Step 1: Open AMP in the Webbrowser
- Step 2: Open the Instance of Factorio
- Step 3: Start the Server
- Step 4: Update the Server
When trying to start the server I get the following console logs:
Console18:54:23
0.011 Loading mod settings car-finder 2.0.0 (settings.lua)
0.011 Loading mod settings DiscoScience 2.0.1 (settings.lua)
0.012 Loading mod settings Honk 5.1.1 (settings.lua)
0.012 Loading mod settings Power Armor MK3 2.1.7 (settings.lua)
0.013 Loading mod settings Todo-List 19.14.1 (settings.lua)
0.013 Loading mod settings AutoDeconstruct 1.0.10 (settings-final-fixes.lua)
0.016 Loading mod core 0.0.0 (data.lua)
0.025 Loading mod base 2.0.72 (data.lua)
0.138 Loading mod VehicleSnap 2.0.3 (data.lua)
0.145 Loading mod Bottleneck 0.12.1 (data.lua)
0.153 Loading mod car-finder 2.0.0 (data.lua)
0.161 Loading mod DiscoScience 2.0.1 (data.lua)
0.169 Loading mod elevated-rails 2.0.72 (data.lua)
0.189 Loading mod Honk 5.1.1 (data.lua)
0.198 Loading mod Power Armor MK3 2.1.7 (data.lua)
0.209 Loading mod quality 2.0.72 (data.lua)
0.222 Loading mod Todo-List 19.14.1 (data.lua)
0.231 Loading mod space-age 2.0.72 (data.lua)
0.379 Loading mod belt-balancer-2 2.0.9 (data.lua)
table
0.395 Loading mod base 2.0.72 (data-updates.lua)
0.412 Loading mod Power Armor MK3 2.1.7 (data-updates.lua)
0.429 Loading mod quality 2.0.72 (data-updates.lua)
0.452 Loading mod space-age 2.0.72 (data-updates.lua)
0.469 Loading mod Honk 5.1.1 (data-final-fixes.lua)
0.485 Loading mod Power Armor MK3 2.1.7 (data-final-fixes.lua)
0.570 Checksum for core: 3316885848
0.570 Checksum of base: 1879415942
0.570 Checksum of VehicleSnap: 2430757830
0.570 Checksum of AutoDeconstruct: 1781807764
0.570 Checksum of Bottleneck: 1340424736
0.570 Checksum of car-finder: 1120809659
0.570 Checksum of DiscoScience: 2800209080
0.570 Checksum of elevated-rails: 70351106
0.570 Checksum of Honk: 793290950
0.570 Checksum of Power Armor MK3: 549337896
0.570 Checksum of quality: 1142589254
0.570 Checksum of Todo-List: 1238941826
0.570 Checksum of space-age: 1510664043
0.570 Checksum of belt-balancer-2: 415171805
18:54:24
0.862 Prototype list checksum: 152868638
0.909 Info PlayerData.cpp:64: Local player-data.json available, timestamp 1765042702
0.909 Info PlayerData.cpp:71: Cloud player-data.json unavailable
0.911 Factorio initialised
0.911 Info ServerSynchronizer.cpp:22: nextHeartbeatSequenceNumber(0) initialized Synchronizer nextTickClosureTick(0).
0.911 Info ServerMultiplayerManager.cpp:808: updateTick(18446744073709551615) changing state from(Ready) to(PreparedToHostGame)
0.911 Info ServerMultiplayerManager.cpp:808: updateTick(18446744073709551615) changing state from(PreparedToHostGame) to(CreatingGame)
0.911 Loading map /AMP/factorio/server/saves/spaceage.zip: 20855628 bytes.
0.922 Loading level.dat: 52095072 bytes.
0.922 Info Scenario.cpp:154: Map version 2.0.72-0
1.547 Blueprint storage "blueprint-storage-2.dat" was not found, trying to load previous version storage "blueprint-storage.dat"
1.547 Loading script.dat: 317719 bytes.
1.549 Checksum for script __level__/control.lua: 2722821277
1.550 Checksum for script __VehicleSnap__/control.lua: 2163719687
1.552 Checksum for script __AutoDeconstruct__/control.lua: 3163424602
1.553 Checksum for script __Bottleneck__/control.lua: 83028149
1.554 Checksum for script __car-finder__/control.lua: 4090552566
1.555 Checksum for script __DiscoScience__/control.lua: 2090411717
1.556 Checksum for script __Honk__/control.lua: 3606101868
1.558 Checksum for script __Todo-List__/control.lua: 2953055564
1.561 Checksum for script __belt-balancer-2__/control.lua: 310112443
1.582 Info UDPSocket.cpp:37: Opening socket at (IP ADDR:({0.0.0.0:34197}))
1.582 Hosting game at IP ADDR:({0.0.0.0:34197})
1.582 Info HttpSharedState.cpp:57: Downloading https://auth.factorio.com/generate-server-padlock-2?api_version=6
1.582 Error HttpSharedState.cpp:177: CURL failed: code:6, 6; Could not resolve host: auth.factorio.com
1.582 Info HttpSharedState.cpp:186: Downloading https://auth.factorio.com/generate-server-padlock-2?api_version=6
1.582 Info HttpSharedState.cpp:187: Status code: 0
1.583 Info AuthServerConnector.cpp:35: Failed to reach auth server: code(520) message(Could not resolve host: auth.factorio.com)
1.583 Error ServerMultiplayerManager.cpp:84: MultiplayerManager failed: Failed to reach auth server. Code: 520. Error: Unknown error.
1.583 Info ServerMultiplayerManager.cpp:808: updateTick(9567576) changing state from(CreatingGame) to(InitializationFailed)
1.583 Info CommandLineMultiplayer.cpp:211: Exit point.
1.583 Info GlobalContext.cpp:775: Deleting active scenario.
18:54:25
1.666 Info ServerMultiplayerManager.cpp:119: Disconnecting multiplayer connection.
1.666 Info ServerMultiplayerManager.cpp:808: updateTick(18446744073709551615) changing state from(InitializationFailed) to(DisconnectingScheduled)
1.685 Info ServerMultiplayerManager.cpp:146: Quitting multiplayer connection.
1.685 Info ServerMultiplayerManager.cpp:808: updateTick(18446744073709551615) changing state from(DisconnectingScheduled) to(Closed)
1.685 Info ServerMultiplayerManager.cpp:166: Deleting active scenario (global = true).
1.782 Info UDPSocket.cpp:237: Closing socket
1.782 Info UDPSocket.cpp:267: Socket closed
1.783 Goodbye
18:54:28
0.015 Loading mod settings DiscoScience 2.0.1 (settings.lua)
0.017 Loading mod settings Honk 5.1.1 (settings.lua)
0.019 Loading mod settings Power Armor MK3 2.1.7 (settings.lua)
0.019 Loading mod settings Todo-List 19.14.1 (settings.lua)
0.020 Loading mod settings AutoDeconstruct 1.0.10 (settings-final-fixes.lua)
0.022 Loading mod core 0.0.0 (data.lua)
0.032 Loading mod base 2.0.72 (data.lua)
0.144 Loading mod VehicleSnap 2.0.3 (data.lua)
0.152 Loading mod Bottleneck 0.12.1 (data.lua)
0.161 Loading mod car-finder 2.0.0 (data.lua)
0.170 Loading mod DiscoScience 2.0.1 (data.lua)
0.179 Loading mod elevated-rails 2.0.72 (data.lua)
0.199 Loading mod Honk 5.1.1 (data.lua)
0.208 Loading mod Power Armor MK3 2.1.7 (data.lua)
0.218 Loading mod quality 2.0.72 (data.lua)
0.231 Loading mod Todo-List 19.14.1 (data.lua)
0.241 Loading mod space-age 2.0.72 (data.lua)
0.386 Loading mod belt-balancer-2 2.0.9 (data.lua)
table
0.402 Loading mod base 2.0.72 (data-updates.lua)
0.417 Loading mod Power Armor MK3 2.1.7 (data-updates.lua)
0.433 Loading mod quality 2.0.72 (data-updates.lua)
0.458 Loading mod space-age 2.0.72 (data-updates.lua)
0.474 Loading mod Honk 5.1.1 (data-final-fixes.lua)
0.490 Loading mod Power Armor MK3 2.1.7 (data-final-fixes.lua)
0.574 Checksum for core: 3316885848
0.574 Checksum of base: 1879415942
0.574 Checksum of VehicleSnap: 2430757830
0.574 Checksum of AutoDeconstruct: 1781807764
0.574 Checksum of Bottleneck: 1340424736
0.574 Checksum of car-finder: 1120809659
0.574 Checksum of DiscoScience: 2800209080
0.574 Checksum of elevated-rails: 70351106
0.574 Checksum of Honk: 793290950
0.574 Checksum of Power Armor MK3: 549337896
0.574 Checksum of quality: 1142589254
0.574 Checksum of Todo-List: 1238941826
0.574 Checksum of space-age: 1510664043
0.574 Checksum of belt-balancer-2: 415171805
18:54:29
0.873 Prototype list checksum: 152868638
0.926 Info PlayerData.cpp:64: Local player-data.json available, timestamp 1765043665
0.926 Info PlayerData.cpp:71: Cloud player-data.json unavailable
0.927 Factorio initialised
0.927 Info ServerSynchronizer.cpp:22: nextHeartbeatSequenceNumber(0) initialized Synchronizer nextTickClosureTick(0).
0.927 Info ServerMultiplayerManager.cpp:808: updateTick(18446744073709551615) changing state from(Ready) to(PreparedToHostGame)
0.927 Info ServerMultiplayerManager.cpp:808: updateTick(18446744073709551615) changing state from(PreparedToHostGame) to(CreatingGame)
0.928 Loading map /AMP/factorio/server/saves/spaceage.zip: 20855628 bytes.
0.939 Loading level.dat: 52095072 bytes.
0.939 Info Scenario.cpp:154: Map version 2.0.72-0
1.576 Blueprint storage "blueprint-storage-2.dat" was not found, trying to load previous version storage "blueprint-storage.dat"
1.576 Loading script.dat: 317719 bytes.
1.578 Checksum for script __level__/control.lua: 2722821277
1.579 Checksum for script __VehicleSnap__/control.lua: 2163719687
1.581 Checksum for script __AutoDeconstruct__/control.lua: 3163424602
1.582 Checksum for script __Bottleneck__/control.lua: 83028149
1.583 Checksum for script __car-finder__/control.lua: 4090552566
1.584 Checksum for script __DiscoScience__/control.lua: 2090411717
1.585 Checksum for script __Honk__/control.lua: 3606101868
1.587 Checksum for script __Todo-List__/control.lua: 2953055564
1.591 Checksum for script __belt-balancer-2__/control.lua: 310112443
1.611 Info UDPSocket.cpp:37: Opening socket at (IP ADDR:({0.0.0.0:34197}))
1.611 Hosting game at IP ADDR:({0.0.0.0:34197})
1.611 Info HttpSharedState.cpp:57: Downloading https://auth.factorio.com/generate-server-padlock-2?api_version=6
1.612 Error HttpSharedState.cpp:177: CURL failed: code:6, 6; Could not resolve host: auth.factorio.com
1.612 Info HttpSharedState.cpp:186: Downloading https://auth.factorio.com/generate-server-padlock-2?api_version=6
1.612 Info HttpSharedState.cpp:187: Status code: 0
1.612 Info AuthServerConnector.cpp:35: Failed to reach auth server: code(520) message(Could not resolve host: auth.factorio.com)
1.612 Error ServerMultiplayerManager.cpp:84: MultiplayerManager failed: Failed to reach auth server. Code: 520. Error: Unknown error.
1.612 Info ServerMultiplayerManager.cpp:808: updateTick(9567576) changing state from(CreatingGame) to(InitializationFailed)
1.612 Info CommandLineMultiplayer.cpp:211: Exit point.
1.612 Info GlobalContext.cpp:775: Deleting active scenario.
1.694 Info ServerMultiplayerManager.cpp:119: Disconnecting multiplayer connection.
1.694 Info ServerMultiplayerManager.cpp:808: updateTick(18446744073709551615) changing state from(InitializationFailed) to(DisconnectingScheduled)
1.713 Info ServerMultiplayerManager.cpp:146: Quitting multiplayer connection.
1.713 Info ServerMultiplayerManager.cpp:808: updateTick(18446744073709551615) changing state from(DisconnectingScheduled) to(Closed)
1.713 Info ServerMultiplayerManager.cpp:166: Deleting active scenario (global = true).
1.811 Info UDPSocket.cpp:237: Closing socket
1.811 Info UDPSocket.cpp:267: Socket closed
1.812 Goodbye
When clicking on Update I get this error:
Resource temporarily unavailable (factorio.com:443)
Connected to the server via SSH and tested the following:
root@amp:~# ping -c 4 auth.factorio.com
PING auth.factorio.com (104.26.14.88) 56(84) bytes of data.
64 bytes from 104.26.14.88: icmp_seq=1 ttl=60 time=11.3 ms
64 bytes from 104.26.14.88: icmp_seq=2 ttl=60 time=11.1 ms
64 bytes from 104.26.14.88: icmp_seq=3 ttl=60 time=11.3 ms
64 bytes from 104.26.14.88: icmp_seq=4 ttl=60 time=11.0 ms
--- auth.factorio.com ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 11.005/11.160/11.277/0.114 ms
root@amp:~# ping -c 4 factorio.com
PING factorio.com (172.67.71.197) 56(84) bytes of data.
64 bytes from 172.67.71.197: icmp_seq=1 ttl=60 time=11.2 ms
64 bytes from 172.67.71.197: icmp_seq=2 ttl=60 time=11.0 ms
64 bytes from 172.67.71.197: icmp_seq=3 ttl=60 time=11.1 ms
64 bytes from 172.67.71.197: icmp_seq=4 ttl=60 time=11.1 ms
--- factorio.com ping statistics ---
rtt min/avg/max/mdev = 10.961/11.083/11.205/0.088 ms
root@amp:~# nc -vz factorio.com 443
Warning: inverse host lookup failed for 172.67.71.197: Unknown host
Warning: inverse host lookup failed for 104.26.14.88: Unknown host
Warning: inverse host lookup failed for 104.26.15.88: Unknown host
factorio.com [172.67.71.197] 443 (https) open
