OS Name/Version:
Ubuntu 22.04.5 LTS
AMP Instance Manager v2.6.2.2 built 06/07/2025 05:40
Migrated an instance from one server to another. Both running same version of AMP.
Ran --rebind to change IP, ran reactivate, ran reauth to make sure everything works. I get the instance to come up, but everything I make a config change to that instance, server setting or backup setting. The next reboot I get
[16:33:21] [System Error/7] : Phone home rejected for Professional : NoLicenceFile - AMP may not restart!
I run the reactivate and get the same error the next time.
[16:31:10] [Program Info/1] : Starting AMP version 2.6.2.2 (Phobos), built 06/07/2025 05:39
[16:31:10] [Program Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[16:31:10] [Program Info/1] : Running in a Docker environment.
[16:31:10] [Program Info/1] : OS: Linux / x86_64
[16:31:10] [Program Info/1] : CPU: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz (6C/6T)
[16:31:10] [Program Info/1] : RAM: 9940MB
[16:31:10] [Program Info/1] : AMP Instance ID: 78d3c1fd-12d3-4fa2-b108-f4660b784697
[16:31:11] [Generic Info/1] : 4 Legacy ports migrated.
[16:31:12] [Core Info/1] : Loaded GenericModule version 2.6.2.2 by CubeCoders Limited
[16:31:12] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[16:31:12] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[16:31:12] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[16:31:12] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[16:31:12] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[16:31:12] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[16:31:12] [Loader Error/1] : Container failed to resolve plugin AnalyticsPlugin
[16:31:12] [Loader Error/1] : Resolution failed with error: Exception has been thrown by the target of an invocation.
For more detailed information run Unity in debug mode: new UnityContainer().AddExtension(new Diagnostic())
[16:31:12] [Loader Fatal/1] : ‘AnalyticsPlugin’ does not implement abstract class ‘ModuleShared.AMPPlugin’
[16:31:12] [Core Error/1] : Could not load plugin AnalyticsPlugin
[16:31:12] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[16:31:12] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[16:31:12] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[16:31:12] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[16:31:13] [Loader Notice/1] : Using keypair with fingerprint 8O8n+sioR7ISSoEnTEHwVvDh7Pt9FhnHXd7acxB6FIE=
[16:31:13] [Loader Info/1] : SFTP Server started on 0.0.0.0:2230
[16:31:13] [Core Warning/1] : Expected licence feature RunAMP is not present.
[16:31:13] [Core Error/1] : No valid AMP licence was found. Please open a shell as the ‘amp’ user and run ampinstmgr reactivate J2-7days01
to reactivate this instance.
[16:31:13] [Core Info/1] : Available features:
[16:31:13] [Core Info/1] : Active Licences:
root@amp11:/home/amp2/J2-7days01/AMP_Logs# sudo -u amp /usr/bin/ampinstmgr stop ADS01
[Info/1] AMP Instance Manager v2.6.2.2 built 06/07/2025 05:40
[Info/1] Stopping Instance: ‘ADS01’
[Info/1] Stopping instance ADS01…
[Info/1] Requesting soft-stop…
[Info/1] Waiting for instance to stop…
[Info/10] Instance was shut down gracefully.
[Info/10] Instance ADS01 has stopped.
root@amp11:/home/amp2/J2-7days01/AMP_Logs# cd AMP_Logs/^C
root@amp11:/home/amp2/J2-7days01/AMP_Logs# sudo -u amp /usr/bin/ampinstmgr stop J2-7days01
[Notice/1] J2-7days01 is already stopped.
root@amp11:/home/amp2/J2-7days01/AMP_Logs# sudo -u amp /usr/bin/ampinstmgr reactivate J2-7days01
Please enter value for Licence Key
[Info/1] Checking licence key…
[Info/6] Licence Type: AMP Professional
[Info/6] Current Usage: 7
[Info/6] Reactivating instance J2-7days01…
[Info/6] d5198a6116f90e860793b0d987951d00a8b129bc57870de02cbe366d7863dde8
[Info/10] Done.
root@amp11:/home/amp2/J2-7days01/AMP_Logs# sudo -u amp /usr/bin/ampinstmgr start ADS01
[Info/1] Starting Instance: ‘ADS01’
[Info/1] Waiting for AMP instance to start…
[Notice/7] AMP instance ADS01 is now running.
[Info/9] You can browse to this instance at http://192.168.1.71:8080/
[Info/9] Instance started in new session. Run ‘ampinstmgr View ADS01’ to view this instances live output.
AMPLOG\ 2025-07-10\ 16-32-54.log
Does Reconfig
[16:32:59] [Core Info/1] : Performing activation, please wait…
[16:33:00] [Core Info/1] : Activated successfully.
[16:33:00] [Core Info/1] : Licence Present: AMP Professional Edition - Lifetime Licence
[16:33:00] [Program Info/1] : -configonly specified or activation performed. Saving settings and shutting down. This is perfectly normal.
AMPLOG\ 2025-07-10\ 16-33-16.log
[16:33:17] [Program Info/1] : Starting AMP version 2.6.2.2 (Phobos), built 06/07/2025 05:39
[16:33:17] [Program Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[16:33:17] [Program Info/1] : Running in a Docker environment.
[16:33:17] [Program Info/1] : OS: Linux / x86_64
[16:33:17] [Program Info/1] : CPU: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz (6C/6T)
[16:33:17] [Program Info/1] : RAM: 9940MB
[16:33:17] [Program Info/1] : AMP Instance ID: 78d3c1fd-12d3-4fa2-b108-f4660b784697
[16:33:19] [Generic Info/1] : 4 Legacy ports migrated.
[16:33:19] [Core Info/1] : Loaded GenericModule version 2.6.2.2 by CubeCoders Limited
[16:33:19] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[16:33:20] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[16:33:20] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[16:33:20] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[16:33:20] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[16:33:20] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[16:33:20] [Loader Error/1] : Container failed to resolve plugin AnalyticsPlugin
[16:33:20] [Loader Error/1] : Resolution failed with error: Exception has been thrown by the target of an invocation.
[16:33:20] [Loader Fatal/1] : ‘AnalyticsPlugin’ does not implement abstract class ‘ModuleShared.AMPPlugin’
[16:33:20] [Core Error/1] : Could not load plugin AnalyticsPlugin
[16:33:20] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[16:33:20] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[16:33:20] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[16:33:20] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[16:33:20] [Core Info/1] : Licence Present: AMP Professional Edition - Lifetime Licence
[16:33:21] [Loader Notice/1] : Using keypair with fingerprint 8O8n+sioR7ISSoEnTEHwVvDh7Pt9FhnHXd7acxB6FIE=
[16:33:21] [Loader Info/1] : SFTP Server started on 0.0.0.0:2230
[16:33:21] [Core Warning/1] : Expected licence feature RunAMP is not present.
[16:33:21] [Core Error/1] : No valid AMP licence was found. Please open a shell as the ‘amp’ user and run ampinstmgr reactivate J2-7days01
[16:33:21] [Core Info/1] : Available features:
[16:33:21] [Core Info/1] : Active Licences:
-Make any setting change to instance
-Stop/Start instance.
