Instance Metrics Not Working
OS Name/Version:
  • NAME=“Debian GNU/Linux”
  • VERSION=“12 (bookworm)”
Hello,
I am experiencing an issue with my Raspberry Pi where the metrics displayed in my Minecraft instance panel show a constant value of 0. I don’t recall ever having the metrics function correctly in my instances. I’m not sure what I should do to try and fix this so I’m reaching out to see if there is a solution, as having these metrics available would be very helpful.
Thanks in advance.
  • Step 1: Configure Raspberry Pi to boot from USB
  • Step 2: Use Raspberry Pi Imager to install Raspberry Pi OS Lite (64-bit) on an SSD
  • Step 2: Boot up and install AMP using the one-line install command
  • Step 3: Create a new Minecraft Java instance and run it
  • Boot from an SD card instead of SSD
  • Tried different OS (Ubuntu)
i have similar issues, file manager has disspeared with this version!
What do you mean by file manager has disappeared? The file manager works fine for me. Just not the metrics.
