Instance Metadata
Hiya,
I’m trying to find a way of grouping and identifying instances. As far as I can tell the API doesn’t expose the Display Group via Instance Summary or any other method, but I have noticed a Tags field - but I can’t see anywhere in the web UI to define any tags.
I’d rather use something like these options rather than having an identifier as part of the Instance Name and then doing some string manipulation to get at it (although if that’s my only realistic option then so be it!).
Any light that could be shed on this would be much appreciated!
