Instance Deployment Defaults Not Applying Correctly
OS Name/Version: Windows Server 2025
Product Name/Version: 2.6.3.2 - 20251022.1
When creating a new instance from the controller, instances do not follow defaults set in the deployment defaults. Settings such as Core.Login.AuthServerURL or Core.Security.EnablePassthruAuth do not seem to take effect, and will be provisioned with their standard defaults of 127.0.0.1 and false respectively. However if the instances is deployed either from the target directly or from the target by managing the target from the controller, the defaults I set do take effect.
  • Set deployment defaults on both target and controller
  • Deploy an instance to the target from the controller
  • Deploy an instance to the target from the target
  • Check the config file to verify the controller-deployed instance does not get the specified defaults and the target-deployed instance does get them.
Actions taken to resolve so far: Verified that settings name/tags were correct by deploying instance from the target with the expected behavior. Editing the above values was the solution to another issue of being unable to manage instances from the controller.
