Installing AMP panel on aarch64 system is failing, issue with download mirror
OS Name/Version: Ubuntu 24.04.2 LTS
Product Name/Version: AMP Instance Manager v2.6.2
Problem Description: Running the installation script on the server is failing to download the panel from the download mirror. The mirror is throwing up a 404 when the script tries to download AMP from the download mirror.
Step 1: Run getAMP script (on aarch64 server)
Step 2: Configure installation and begin installing AMP
Step 3: Wait
Actions taken to resolve so far: Disabled ipv6 and retried.
The download mirror that the getamp script is using to download AMP for aarch64 is giving an error when accessing it from both the server and various different clients (broken download link: https://cdn-downloads.c7rs.com/AMP/Mainline/20250528.3/AMP_aarch64.zip)
Same problem here. Seems like aarch64 build is not available.
When checking the folders for an older version, it’s available:
Is there any way to force installing an old version as a workaround until an aarch64 build is available?
