Installing amp not working
OS Name/Version: Debian 13.2.0
Product Name/Version: Amp 2.6.4
Problem Description: won’t install
Installing AMP...
amp already exists. Skipping...
Updating System...
Installing prerequisites...
Installing Docker...
Adding CubeCoders DEB repository...
Installing instance manager...
 - Installing via package manager...
Failed to install instance manager. Aborting...
Possible causes for this are an unsupported distribution, or the repository being in the middle of a sync. In which
case wait 30 minutes and try again, re-running the same installation command.
Something went wrong during the installation. Would you like to upload your setup log for easy sharing?
This will upload /root/getamp-20251116-205410.log to the hastebin service and give you a URL you can share.
The log file may contain sensitive information such as username, any supplied domain names or your systems hostname so
if in doubt - check the file manually and upload it yourself.
  • Step 1 sudo su -
  • Step 2 bash <(wget -qO- getamp.sh)
  • Step 3 run installer
Actions taken to resolve so far: waiting 30 minutes and trying again multiple times
What is the output when you run apt update as root?
Please supply the log file it mentions, after checking it for personal information.
how do I do that sorry I’m new to this
