Initialization issue when updating Minecraft instance
OS Name/Version:
Ubuntu 20.04.4 LTS
v2.3.2.4, built 21/02/2022
Every time the container memory is updated in the instance using UpdateInstanceInfo, all settings set in the instance are initialized. Is there a way to prevent that setting from being reset?
Hey @hch99000,
I noticed your post hasn’t gotten a reply, and I wanted to try and help! You’re currently running AMP v2.3.2.4, which is a pretty old version from early 2022. Since then, there have been multiple updates, so this issue might already be fixed.
Next Steps:
  1. Upgrade AMP to the latest version—this ensures you’re working with the newest bug fixes and improvements.
  2. Test whether the issue persists after updating.
  3. If the settings are still resetting, let me know! I’ll help troubleshoot further.
Hope this helps, and let me know how it goes!
Cheers,
Francisco
