Initial Setup Issues
OS Name/Version: Windows 10
Product Name/Version: AMP 2.3.2.0
Problem Description: Installed using the exe file from the website, entered purchased key but when it asks me to create my first instance, it fails with a warning box saying “Unable to create instance - The core archive failed to download or unpack” I have tried running as administrator, can’t find any reference to this error. Any help would be great!
Thanks in Advance.
In %LOCALAPPDATA%/CubeCoders/AMP/InstanceManager you’ll find some log files that might give some clue as to what it’s unhappy about.
I’d also suggest wiping AMPs cache files in X:\AMPDatastore\Instances\ - They’re the AMPCache-XXXX.zip files.
SOLVED
AMP had installed the DATAstore folder on a removable drive and I was trying to run AMP without the drive in.
New Issue though, I am trying to use a FiveM instance however I can get a new instance to show in the console but when I press start, the start button disappears, it thinks for a while, then the start button reappears. I have tried to do that then connect regardless but no luck. Any ideas?
Cam
Please create a new thread for new issues. One issue per thread please.
