I have two computers running AMP and I want to replace one of them with a better one, but I don’t know if I can just copy the instances when I install it on my new PC, or if I have to manually create the same instances and then copy and paste only the game worlds. Is there an import feature where you can just take the whole instance and import it? I have about 20 instances, but creating new ones and then importing them one by one would just be a hassle.
There are a few ways to migrate things by hand:
https://discourse.cubecoders.com/t/migrating-instances-to-a-new-machine/532/8
https://discourse.cubecoders.com/t/moving-instances-from-one-amp-server-to-another-with-existing-instances/18341
If you don’t have any instances on the new install you can run through the first post, otherwise the second post should get you rolling.
