is there a way back? i didnt meant to activate dev and now i can use my key. i clicked on a button and didnt knew it would do this.
You need to use your actual license key.
You can do so by going to New Instance Defaults
and entering the key there, then reactivate the local instances if needed.
Otherwise you can run ampinstmgr reactivate
or ampinstmgr reactivateall
to reactivate the specified instance(s) with the right key.
