I enabled HTTPS on my AMP instance and locked myself out
OS Name/Version: Debian 12
Product Name/Version: AMP 26.0.0.0 Phobos
Problem Description: I used the enable HTTPS feature from the command line and now I cannot access the GUI anymore after a certificate error. How can I revert AMP back to using port 8080?
provides syntax highlighting.
  • Step 1
  • Step 2
  • Step 3
Actions taken to resolve so far: Resetted the instance
Have you tried to go to https://ipaddress?
Gives me This site can’t be reached
10.0.1.50 refused to connect.
Try:
  • Checking the connection
  • Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
Did you follow this guide when setting up?
Can you log into the vm and check the logs for ads01?
I’m sorry but how do I do that again? I know how to access the amp user.
To enable the logs use
ampinstmgr reconfigure ADS01 +Core.Monitoring.LogLevel 0
Read through this for viewing the log. When I get home later I can assist more.
Hi Sara, not sure if you got any further on your issue today.
but if you’d like to check your logs you can do so by getting into the docker instance with the following commands.
log into VM
get into the AMP user.
su -l amp
ampinstmgr --lastlog instancename
scratch this below:
docker exec -it DockerInstance bash
cd /AMP/AMP_Logs/
and see the latest log in that direction. if you’re using the cli you can use cat logfilename.log
Why do you keep suggesting that people exec into the Docker container? The files are readily available.
You can even run ampinstmgr lastlog TheInstanceName to see them
I did correct this. I’m used to just exec into the docker instance. my apologies PotatoKing.
