I am Facing Issues with AMP Setup – want Help with Logs & Config
Hey everyone,
I am setting up AMP on a fresh serverl. Everything was running fine until I started playing around with additional modules and custom configs. I am getting stuck on startup errors that do not seem too descriptive. Also I checked the logs but I can not quite figure out what is going wrong. It seems such as something is clashing during the instance startup phase.
Also I have tried restarting, rechecking the ports & even a fresh reinstall but still no luck. Has anyone here faced similar issues after tweaking AMP configs or adding extra services? Want to hear how you troubleshooted it.
Also, while dealing with these server tools, I have been learning project management stuff in parallel and recently came across a pretty solid JIRA Course that explained workflows & issue tracking in a super simple way. Helped me organize this debugging mess a bit better :sweat_smile:
Thank you.:slight_smile:
Thread closed for not following the template. Do not erase the template, all posts in this category are required to follow it.
