OS Name/Version: Ubuntu 22.04 LTS
Product Name/Version: AMP Instance Manager v2.4.1.2 built 21/12/2022 17:55
After recent update had issues connecting from Hybrid instance to my Target server.
Authentication Failure
The remote server rejected the login credentials: Token Rejected
Please check configuration
Basically just did the update rebooted the machines and then suddenly authentication and RoleManagment stuff was all screwed up.. Didn’t have perms on the server or anything.
[20:01:39] [Core Info] : Starting AMP version 2.4.1.2 (Halimede), built 21/12/2022 17:54
[20:01:39] [Core Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[20:01:40] [Core Info] : Loading configuration from provisionargs.kvp...
[20:01:40] [Core Warning] : Current time zone is set to CST - It is recommended you switch to UTC+0 to avoid time-zone related issues
[20:01:40] [Core Info] : OS: Linux / x86_64
[20:01:40] [Core Info] : CPU: AMD Ryzen 7 2700X Eight-Core Processor (8C/16T)
[20:01:40] [Core Info] : AMP Instance ID: 08c5e119-9210-462e-b166-21f1f26a7ed4
[20:01:40] [ModuleLoader Info] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[20:01:40] [Core Info] : Metrics publishing is enabled at udp://amp.ltcraft.net:12820.
[20:01:40] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[20:01:40] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[20:01:40] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[20:01:40] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[20:01:40] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[20:01:40] [ModuleLoader Info] : ADSModule requests dependency InstanceManagerPlugin...
[20:01:40] [ModuleLoader Info] : Loaded InstanceManagerPlugin version 1.0.0.0 by CubeCoders Limited
[20:01:40] [ModuleLoader Info] : ADSModule requests dependency SystemUserManagerPlugin...
[20:01:40] [ModuleLoader Info] : Loaded SystemUserManagerPlugin version 1.0.0.0 by CubeCoders Limited
[20:01:40] [Core Info] : -configonly specified or activation performed. Saving settings and shutting down. This is perfectly normal.
CubeCoders AMP 💻amp@lt1700 📁~/.ampdata/instances/ADS01/AMP_Logs cat AMPLOG\ 2023-02-04\ 20-01-48.log
[20:01:48] [Core Info] : Starting AMP version 2.4.1.2 (Halimede), built 21/12/2022 17:54
[20:01:48] [Core Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[20:01:48] [Core Warning] : Current time zone is set to CST - It is recommended you switch to UTC+0 to avoid time-zone related issues
[20:01:48] [Core Info] : OS: Linux / x86_64
[20:01:48] [Core Info] : CPU: AMD Ryzen 7 2700X Eight-Core Processor (8C/16T)
[20:01:48] [Core Info] : AMP Instance ID: 08c5e119-9210-462e-b166-21f1f26a7ed4
[20:01:49] [Core Fatal] : The auth server URL is set to be the same URL as this AMP instances own webserver. This is not allowed as it would cause a loop.
I think I might have fixed it again with this not sure..
CubeCoders AMP 💻amp@lt1700 📁~/.ampdata/instances/ADS01 ampinstmgr --RebindInstance ADS01
[Info] AMP Instance Manager v2.4.1.2 built 21/12/2022 17:55
Please enter value for IP Binding
>localhost
Please enter value for Port Number
>8080
[Warning] WARNING: Rebinding ADS will break logins/management for all instances/controllers that rely on it.
[Error] -- You will not be able to manage any existing instances if you do this --
[Warning] If you are not familiar with how AMP manages authentication and logins, ask for support before doing this.
[Info] This prompt is case-sensitive. You should avoid rebinding ADS if at all possible.
Are you sure you want to rebind ADS? You will need to manually reconfigure any managed instances. [Y/N]
>Y
[Info] Reconfiguring instance ADS01...
[22:04:31] [Core Info] : Starting AMP version 2.4.1.2 (Halimede), built 21/12/2022 17:54
[22:04:31] [Core Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[22:04:31] [Core Info] : Loading configuration from provisionargs.kvp...
[22:04:31] [Core Warning] : Current time zone is set to CST - It is recommended you switch to UTC+0 to avoid time-zone related issues
[22:04:31] [Core Info] : OS: Linux / x86_64
[22:04:31] [Core Info] : CPU: AMD Ryzen 7 2700X Eight-Core Processor (8C/16T)
[22:04:31] [Core Info] : AMP Instance ID: 08c5e119-9210-462e-b166-21f1f26a7ed4
[22:04:32] [Core Fatal] : The auth server URL is set to be the same URL as this AMP instances own webserver. This is not allowed as it would cause a loop.
[Info] Done. Use --ShowInstancesList to see your changes.
[Warning] You should now run `ampinstmgr repairauth` on this system as well as any other AMP targets.
CubeCoders AMP 💻amp@lt1700 📁~/.ampdata/instances/ADS01 ampinstmgr repairauth
Which mode is ADS configured as? 'standalone', 'controller', 'target' or 'hybrid'? If you do not know, press CTRL+C to abort.
>target
What is the URL of your controller/standalone instance? This URL must be accessible from all targets in a multi-target setup.
>amp.ltcraft.net
[Warning] Bad URL: amp.ltcraft.net
>target
>https://amp.ltcraft.net
[Info] Stopping Instance: 'Rust01'
[Info] Stopping instance Rust01...
[Info] Requesting soft-stop...
[Info] Waiting for instance to stop...
[Info] Instance Rust01 has stopped.
[Info] Stopping Instance: 'Ltcraft-Live01'
[Info] Stopping instance Ltcraft-Live01...
[Info] Instance Ltcraft-Live01 has stopped.
[Info] Stopping Instance: 'Ltcraft-Development01'
[Info] Stopping instance Ltcraft-Development01...
[Info] Instance Ltcraft-Development01 has stopped.
[22:06:03] [Core Info] : Starting AMP version 2.4.1.2 (Halimede), built 21/12/2022 17:54
[22:06:03] [Core Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[22:06:03] [Core Info] : Loading configuration from provisionargs.kvp...
[22:06:03] [Core Warning] : Current time zone is set to CST - It is recommended you switch to UTC+0 to avoid time-zone related issues
[22:06:03] [Core Info] : OS: Linux / x86_64
[22:06:03] [Core Info] : CPU: AMD Ryzen 7 2700X Eight-Core Processor (8C/16T)
[22:06:03] [Core Info] : AMP Instance ID: 08c5e119-9210-462e-b166-21f1f26a7ed4
[22:06:03] [Core Fatal] : The auth server URL is set to be the same URL as this AMP instances own webserver. This is not allowed as it would cause a loop.
[Info] Reconfiguring Instances...
[Info] Reconfiguring Rust01...
[22:06:03] [Core Info] : AMP Instance ID: e9a85b8e-e4ba-4dbb-9b00-d312ea96cc33
[22:06:04] [ModuleLoader Info] : Loaded RustModule version 1.0.0.0 by CubeCoders Limited
[22:06:04] [Core Info] : Metrics publishing is enabled at udp://amp.ltcraft.net:12820.
[22:06:04] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[22:06:04] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[22:06:04] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[22:06:04] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[22:06:04] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[22:06:04] [ModuleLoader Info] : RustModule requests dependency steamcmdplugin...
[22:06:04] [ModuleLoader Info] : Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
[22:06:04] [ModuleLoader Info] : RustModule requests dependency RCONPlugin...
[22:06:04] [RCON Info] : Starting Source RCON Passthru server at 0.0.0.0:7777
[22:06:04] [ModuleLoader Info] : Loaded RCONPlugin version 1.0.0.1 by CubeCoders Limited
[22:06:04] [Core Info] : Licence Present: AMP Network Standard Edition
[22:06:04] [Core Info] : -configonly specified or activation performed. Saving settings and shutting down. This is perfectly normal.
[Info] Reconfiguring Ltcraft-Live01...
[22:06:04] [Core Info] : Starting AMP version 2.4.1.2 (Halimede), built 02/02/2023 03:00
[22:06:04] [Core Info] : Stream: Nightly (Nightly) - built by CUBECODERS/buildbot on CCL-DEV
[22:06:04] [Core Info] : Loading configuration from provisionargs.kvp...
[22:06:05] [Core Warning] : Current time zone is set to CST - It is recommended you switch to UTC+0 to avoid time-zone related issues
[22:06:05] [Core Info] : OS: Linux / x86_64
[22:06:05] [Core Info] : CPU: AMD Ryzen 7 2700X Eight-Core Processor (8C/16T)
[22:06:05] [Core Info] : RAM: 64261MB
[22:06:05] [Core Info] : AMP Instance ID: 1dfba9c5-c5ad-48b3-b28b-cd65ce417129
[22:06:05] [ModuleLoader Info] : Loaded FiveMModule version 1.0.0.0 by CubeCoders Limited
[22:06:05] [Core Info] : Metrics publishing is enabled at udp://amp.ltcraft.net:12820.
[22:06:05] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[22:06:05] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[22:06:05] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[22:06:05] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[22:06:05] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[22:06:05] [Core Info] : Licence Present: AMP Network Standard Edition
[22:06:05] [Core Info] : -configonly specified or activation performed. Saving settings and shutting down. This is perfectly normal.
[Info] Reconfiguring Ltcraft-Development01...
[22:06:05] [Core Info] : Starting AMP version 2.4.1.2 (Halimede), built 02/02/2023 03:00
[22:06:05] [Core Info] : Stream: Nightly (Nightly) - built by CUBECODERS/buildbot on CCL-DEV
[22:06:06] [Core Info] : Loading configuration from provisionargs.kvp...
[22:06:06] [Core Warning] : Current time zone is set to CST - It is recommended you switch to UTC+0 to avoid time-zone related issues
[22:06:06] [Core Info] : OS: Linux / x86_64
[22:06:06] [Core Info] : CPU: AMD Ryzen 7 2700X Eight-Core Processor (8C/16T)
[22:06:06] [Core Info] : RAM: 64261MB
[22:06:06] [Core Info] : AMP Instance ID: de6673e9-b040-4d5e-bd15-2d0c8fc3e027
[22:06:06] [ModuleLoader Info] : Loaded FiveMModule version 1.0.0.0 by CubeCoders Limited
[22:06:06] [Core Info] : Metrics publishing is enabled at udp://amp.ltcraft.net:12820.
[22:06:06] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[22:06:06] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[22:06:06] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[22:06:06] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[22:06:06] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[22:06:06] [Core Info] : Licence Present: AMP Network Standard Edition
[22:06:06] [Core Info] : -configonly specified or activation performed. Saving settings and shutting down. This is perfectly normal.
[Notice] AMP instance ADS01 is now running.
[Info] Done!
[Info] If AMP was originally configured to use https, you can run 'bash <(wget -qO- getamp.sh) postSetupHTTPS' as root.
I can confirm it is not working still.. It just keeps giving me
Refresh in progress…
This was working fine up until today when i updated it.. Actually worked great not sure what changed…
