HumanitZ Server wont start after 1.0 Update
OS Name/Version:
Windows 11
v2.6.5.2, built 28/01/2026 15:59
HumanitZ 1.0 - Released 2/6/26 @ 11am MST-US
With the recent update, they’ve changed the file name structure. Everything in the AMP template is still referencing the old file name. I’ve tried updating various files within AMP but seems to always be overridden once I try to launch the instance/server. I’m not sure how or if I can update the template? The previous file name for game data was “TSSGame”. The new file is “HumanitZServer”. Everything appears to go okay in AMP but the server wont start. The existing kvp & json files certainly still reference the old file which is basically empty. The Any advise would be much appreciated!
provides syntax highlighting.
  • Create Instance
  • Update Instance
  • Start Instance
I’ve tried updating file paths in kvp and json files all the way back to the AMPDatastore file but seems to always be overridden. Maybe I’m just not finding the right one?
i to am having a problem starting a 1.0 server.
The template has been updated
The template has been further updated to add RCON (so that shutdowns are clean), player tracking and config importing. I strongly recommend creating a new instance and transferring any required saves since existing instances can’t get the RCON changes properly. Nothing I can do to avoid that, given the limitations of AMP’s port handling logic for existing instances
Awesome! Thank you for getting that updated and keeping on it! Much appreciated!
