How to set up an SFTP client?
Hi, I need help in setting up an SFTP client, because uploading files the default way doesn’t work for me.
Thanks
i use sftp client name is winscp
i login to server and go to file manager then 3 lines icon
glyphicons_463_server
of servers in top right of the page say collect to sftp
details will pop up and also auto connect is possible tooo
Full Address sftp://your user@ip/fqdn:port/
Host ip/fqdn
Port port
Username your user
Do I need to install something on the pc? allow any ports in the firewall?
I know that SMFP is for files but I don’t know how AMP is using SMFP
SMFP is using TCP protocol or HTTPS? or HTTP?
install FTP software
use credentials to connect and ftp upload to your heats content
of your choice i use winscp and works for me
Do I need to install the WinSCP on the server?
No, just on your desktop to shuttle files over.
I don’t need to do any portforwording?
Because we use Cloudflare to manage our secure tunnel…
So this is why I asked about the protocol and port…
SFTP port should be found on your server under above section
file manager icon is on top right side of screen in that section click it
port is like 2222 or somthing similar if you did not chagne anything
this below will show you port etc to connect to it
Host ip/fqdn
Port port
Username your user
we are not on the same page, the amp is locked behind a firewall… we use Cloudflare tunnels to protect the dashboard.
its a part of Cloudflare zero-trust,
the only thing that I need to know is what service AMP SFTP is using
Thanks for all the help :point_up:
i think i have the info as i have tested connecting directly to my Server
this info was taken from my winscp connnection
i have looked seems like ssh is an option on the list in access tunnels
File transfer protocol = SFTP-5
Cryptographic protocol = SSH-2
SSH implementation = AMP Embedded SSH // AMP
Encryption algorithm = AES-256 SDCTR (AES-NI accelerated)
Compression = No
Server host key fingerprints
SHA-256 = ecdsa-sha2-nistp521 521 2XnH499QWgaapY5om43gWAUgxI
MD5 = ecdsa-sha2-nistp521 521 c9:a7:3:ca
Can change permissions = Yes
Can change ACL = No
Can change owner/group = Yes
Can execute arbitrary command = No
Can create symbolic/hard link = Yes/No
Can lookup user groups = No
Can duplicate remote files = No
Can check available space = No
Can calculate file checksum = Yes
Native text (ASCII) mode transfers = Yes
Additional information
The server supports these SFTP extensions:
newline=“\n”
supported=0x000001BD000000696C65
