OS Name/Version: windows 11
Product Name/Version: 2.3.2
what is the proper format for Storage.StorePath?
I have tried
/z/mc01 this just puts it in the C drive under a folder called Z
/z:/mc01 causes the instance to crash
Z:\mc01\ (and every other combination of this) causes: Unable to start backup
the drive path is “Z:\mc01” what is the format I need to make it back up to that?
also random suggestion, have you ever thought about implementing OneDrive or Google Drive backups in to amp. for easy and safe backups.
[11:17:07] [APIService:admin Warning] : Returned exception from API call LocalFileBackupPlugin/TakeBackup
[11:17:07] [APIService:admin Error] : DirectoryNotFoundException
[11:17:07] [APIService:admin Error] : [0] (DirectoryNotFoundException) : Could not find a part of the path 'Z:\mc01\'.
[11:17:07] [APIService:admin Error] : at IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at IO.Directory.InternalCreateDirectory(String fullPath, String path, Object dirSecurityObj, Boolean checkHost)
at IO.Directory.InternalCreateDirectoryHelper(String path, Boolean checkHost)
at LocalFileBackupPlugin.BackupProvider.TakeBackup(BackupManifest manifest)
at GSMyAdmin.WebServer.WebAttributes.InvokeMethod(String MethodName, JObject Data, IHttpRequest request, IWebSession Session, WebMethodsBase MethodsClass, String RawRequest)
at GSMyAdmin.WebServer.APIService.InvokeAPI(IHttpRequest request, IWebSession Session, JObject Data, String RequestModule, String RequestMethod, String RawRequest)
