Product Name/Version: (Always use the full version number - not ‘Latest’) Temurin 21
Problem Description: I do not know how to “port forward” a selected port using UFW on a VPS, purchased by Hostinger. I am attempting to use votifier for my minecraft server, but cannot figure out how to do so. I have attempted to search for tutorials, but mostly finding ones that don’t work or aren’t attempting the same end goal that votifier requires (Im not sure about that part)
Step 1 Purchase Debian 12 server on Hostinger
Step 2 Obtain Plugins necessary, and connect a server to a minecraft server list such a planet minecraft that has a tester for it.
Step 3 Test server with chosen number that has been put into config, with no response.
Note, this isn’t Hostinger support, just the forum for AMP.
You can use the edit “pen”/“pencil” icon in the main panel to add a port to an instance (under networking), and that is automatically added to the firewall.
The main AMP interface where (I’m assuming) you’re managing your Minecraft server(s).
Unless you aren’t using Hostinger’s pre-installed AMP VPS, then that would would all sound like mumbo-jumbo (in which case you’d want to ask Hostinger’s support for further assistance)
If that’s the protocol that Votifier uses. You can select “both” if you want to play it safe, or double check Votifier’s documentation to see if they have a note in there
Should I have “Exclude from firewall” enabled for the ports? The double check and force-apply did not work. The 5555 port doesn’t pop up in the instance menu, unlike the regular unlike the 25565 and 2224, but is in the ports menu
Excluding the instance from the firewall will prevent the ports from being added (be sure to press the add (plus) and save buttons when adding the port)
You shouldn’t need to, did the port show up when you dumped the firewall rules? Also note, the server must be running and votifier must be loaded for that test of yours to work (check the log to see if it loads correctly)
Running updatefirewall when there’s nothing to update just won’t do anything.
From AMP’s side of things the port should be good to go, so it may be down to configuring Votifier.
Found out the issue. Perhaps it is because my connection IP has numbers and letters, but setting the IP to 0.0.0.0 to listen to all IPs worked in configs. Thanks.
