Im trying to use the Discord Webhook trigger, but seems that it isn’t able to format properly the messages, it just send it as-is (is there any way to uses non-raw messages?). Now I’m trying to use the “Make a POST request to a URI” but it seems to do nothing. Is there extra I should know about this tool to make it work? I’m sending this:
Payload:
"content": null,
"embeds": [
"title": "Hay bajos TPS en la modalidad \"Creativo\"",
"description": "Probablemente hay alguien haciendo una máquina de Lag.\nStaff disponible, favor de ingresar a verificar.",
"color": 16734296
"attachments": []
ContentType: application/json
I’m not posting the webhook by obvious reasons.
Trying this POST in a website or using CURL works perfectly.
Or is there any way to use Embeds through Webhooks?
Didn’t know that AMP logs that things.
Here’s the error:
[19:35:17] [WebRequest:korinocho Error] : Failed to make web request via scheduler.
[19:35:17] [WebRequest:korinocho Error] : Misused header name. Make sure request headers are used with HttpRequestMessage, response headers with HttpResponseMessage, and content headers with HttpContent objects.
