How do I edit the config file direct without using the editor? I get the following message when editing. This file is controlled by AMP - This file is exclusively controlled by AMP and cannot be manually edited. Edit the settings in this file via the Configuration menu. Can I disable this?
No, unfortunately you cannot disable that. Is there a specific reason you don’t want to use the AMP UI?
