How to allow experimental builds for 7 days to die on Amp instance server?
I can see the versions menu but this does not allow for experimental builds only stable ?
does anyone know how to do this please as I am wanting to run a V1 test server and it keeps creating a A21.2 build instead?
Stop server
Find steamcmd.exe in the folder
For example D:\AMPDatastore\Instances\SevenDaysToDie01\seven-days-to-die
Open steamcmd.exe
force_install_dir D:\AMPDatastore\Instances\SevenDaysToDie01\seven-days-to-die\294420
login anonymous
app_update 294420-beta latest_experimental
Wait for the update and then close steamcmd.exe
Start server
Steam>app_update 294420-beta latest_experimental
Success! App ‘294420’ already up to date.
needed -unstable adding to the end!
