Good morning all
By chance is there a posted instructions on how to setup admin access from outside network?? I have setup a admin account for a mate email address and pw even gone in and set up my ports
I have been hunting for sometime now and have been unsuccessful - even YT videos
Are you asking about admin access to the panel or to editing an instance?
If you mean admin access to a game server then youd have to look up how to add admins for that game. In Minecraft for example you’d either have to add them via the console using “op [username]”. As far as I know do most games have an admin option in the games configuration panel too.
Good morning
Yes I have correctly setup a user in the AMP Section
Google ai tells me it might be a 8080 port problem
My issue is I have AMP running Arma Reforger at home if I try to login at work it seems to time out
I have followed the install instructions to the letter
If you are running AMP on a mashine in your local network at home you need to open port 8080 on the mashine and in your router.
