How do I wipe AMP and restore backups?
OS Name/Version: windows 10
Product Name/Version: 2.3.0.8 to 2.3.2.0
Problem Description: I upgraded to 2.3.2.0 but get the message in the GUI that each instance needs to be updated. The upgradeall CLI command appears to succeed but after a reboot I still get the issue. This used to prevent me from starting the instances. I’ve tried a few things and now I don’t see the instances anymore.
I’d like to just have a process to restore the instances after a clean wipe. I don’t think they are gone or renamed. I’ve got a minecraft, satisfactory, and an ark server.
Actions taken to resolve so far: appinstmgr upgradeall with and without cache. reboot afterwards. uninstall via windows add/remove programs.
Hey @Michael_Chiaverini,
I saw your post and wanted to help troubleshoot your AMP instance recovery issue after upgrading to 2.3.2.0. Since your instances disappeared after the upgrade, here’s a structured approach to wipe AMP and restore backups properly.
Steps to Wipe AMP and Restore Backups:
  1. Backup Existing AMP Data – Before wiping AMP, ensure you have a backup of your instances:
    appbackup backupall
    or manually copy the AMPDatastore folder.
  2. Fully Uninstall AMP – Since uninstalling via Windows Add/Remove Programs didn’t work, try manually removing AMP:
    • Stop AMP services:
      appservice stop
    • Delete AMP folders:
      C:\AMP
      C:\AMPDatastore
    • Remove AMP registry entries (if needed).
  3. Reinstall AMP Cleanly – Download and install the latest AMP version from CubeCoders.
  4. Restore Backups – Once AMP is installed, restore your instances:
    appbackup restoreall
    or manually place your backed-up AMPDatastore folder back into AMP’s directory.
  5. Verify Instance Visibility – If instances still don’t appear, check AMP’s logs (AMP/logs) for errors and try manually re-importing instances.
A Few Questions to Help Troubleshoot:
  • Do you still have a backup of your AMPDatastore folder?
  • Does AMP’s log show any errors related to missing instances?
  • Have you tried manually re-importing instances after reinstalling AMP?
Let me know if any of these steps help or if you can provide more details—I’d be happy to troubleshoot further! :rocket:
